Distinguished Contributor
3 Kudos
Post 1 of 5
pline start and end angles
168 Views, 4 Replies
12-03-2012 08:17 AM
is there a function to obtain the start angle and end angle of a pline,i know arcs do
thanks
markruys wrote:
is there a function to obtain the start angle and end angle of a pline....
If 'ent' is the entity name of the Polyline, and you have (vl-load-com) loaded:
(angle '(0 0 0) (vlax-curve-getFirstDeriv ent (vlax-curve-getStartParam ent)))
(angle '(0 0 0) (vlax-curve-getFirstDeriv ent (vlax-curve-getEndParam ent)))
Returned values will be in radians.
669 Kudos
Post 2 of 5
Re: pline start and end angles
12-03-2012 08:50 AM in reply to: markruys
Kent Cooper
190 Kudos
Post 3 of 5
12-03-2012 08:55 AM in reply to: Kent1Cooper
Kent,
Are you sure about the ename?  I believe it is the vla-object:
;;for end angle (in radians)
(setq obj (vlax-ename->vla-object(car(entsel))))
(angle '(0 0 0) (vlax-curve-getFirstDeriv obj (vlax-curve-getEndParam obj)))
669 Kudos
Post 4 of 5
12-03-2012 09:25 AM in reply to: dbroad
Doug:
This question comes up now and then.  The (vlax-curve-...) functions at least, though certainly not all (vla...) functions, work with entity names just as well as with VLA objects.  It spares the need to make the conversion, unless that is also needed to do other things with the same entity, that do require it.  I have loads of routines that do these kinds of things using entity names, and they all work fine.
Kent Cooper
190 Kudos
Post 5 of 5
12-03-2012 09:32 AM in reply to: Kent1Cooper
Thanks.
