Visual LISP, AutoLISP and General Customization
pline start and end angles
4 REPLIES 4
markruys2
395 Views, 4 Replies
is there a function to obtain the start angle and end angle of a pline,i know arcs do
thanks
4 REPLIES 4
Kent1Cooper
in reply to: markruys2
@markruys2 wrote:
is there a function to obtain the start angle and end angle of a pline....
If 'ent' is the entity name of the Polyline, and you have (vl-load-com) loaded:
(angle '(0 0 0) (vlax-curve-getFirstDeriv ent (vlax-curve-getStartParam ent)))
(angle '(0 0 0) (vlax-curve-getFirstDeriv ent (vlax-curve-getEndParam ent)))
Returned values will be in radians.
Kent Cooper, AIA
dbroad
in reply to: Kent1Cooper
Kent,
Are you sure about the ename?  I believe it is the vla-object:
;;for end angle (in radians)
(setq obj (vlax-ename->vla-object(car(entsel))))
(angle '(0 0 0) (vlax-curve-getFirstDeriv obj (vlax-curve-getEndParam obj)))
Architect, Registered NC, VA, SC, & GA.
Kent1Cooper
in reply to: dbroad
Doug:
This question comes up now and then.  The (vlax-curve-...) functions at least, though certainly not all (vla...) functions, work with entity names just as well as with VLA objects.  It spares the need to make the conversion, unless that is also needed to do other things with the same entity, that do require it.  I have loads of routines that do these kinds of things using entity names, and they all work fine.
Kent Cooper, AIA
dbroad
Thanks.
”Boost
