Hi Russell
Try this program:
(defun C:AutoJoin ( / CurSet FltLst FstEnt)
(setq FltLst '((0 . "POLYLINE,LWPOLYLINE,LINE,ARC"))
CurSet (cond ((ssget "I" FltLst)) ((ssget FltLst)))
(if CurSet
(progn
(setq FstEnt (ssname CurSet 0))
(if (member (cdr (assoc 0 (entget FstEnt))) '("LINE" "ARC"))
(command "_.PEDIT" FstEnt "_YES" "_JOIN" CurSet "" "")
(command "_.PEDIT" FstEnt "_JOIN" CurSet "" "")
(princ)
Have a good day...
Cheers
Juerg Menzi
MENZI ENGINEERING GmbH, Switzerland
http://www.menziengineering.ch
Kiwi Russ schrieb:
> If I want to use the pedit command to make lines into plines
> How would I write it along the following method?
> ( Command "pedit" ( the entity is selected) "yes" "join" (select
> all entities to join) "" )
> what I would like is for the user to select entities only once, so the
> sequence is command / pedit / yes / join / then "select entities to join"
> thanks to anyone who can help.....
