PDF prints to wrong dir.
3 REPLIES 3
318 Views, 3 Replies
Hello folks,
hoping someone might have a solution for this that maybe im not seeing.
this lisp code is supposed to write a dwg to a pdf in the same directory as
the dwg
sometimes it works sometimes it doesn't, more doesn't then does.
does anyone see why it wouldn't save to the same directory as the dwg
any help is appreciated
[code]
(defun printpdf (/ fileloc filenam)
(setq fileloc (strcat (getvar "dwgprefix") (vl-filename-base (getvar
"dwgname"))))
(setq filenam (vl-filename-base (getvar "dwgname")))
(command "-plot""y" "" "DWG To PDF.pc3" "ANSI expand A (8.50 x 11.00
Inches)" "I" "P" "N" "E" "F" "" "Y" "nao.ctb" "Y" "" filenam
"n" "y")
[\code]
3 REPLIES 3
maybe its a problem, if the file already exists
you could
(vl-file-delete filenam)
i guess it doesn´t crash, if the file does not exist
and the filenam should be
(setq FILENAM (strcat (getvar "DWGPREFIX") (vl-filename-base (getvar
"DWGNAME"))))
andrew.nao wrote:
> Hello folks,
> the dwg
> [code]
> "dwgname"))))
> "n" "y")
> [\code]
ups sorry
(setq FILENAME (strcat (getvar "DWGPREFIX) (substr (getvar "DWGNAME") 1
(- (strlen (getvar "DWGNAME")) 4))))
> you could
> "DWGNAME"))))
> andrew.nao wrote:
>>Hello folks,
>>the dwg
>>[code]
>>"dwgname"))))
>>"n" "y")
>>[\code]
thanks for your reply
I got it working
”Boost
