Member
JTJSBJB
Message 1 of 6 (1,027 Views)
PC Board Serial Number
1027 Views, 5 Replies
11-28-2010 02:09 AM
Hi everybody,
I've been using AutoCAD since AotuCAD R12, Since then I'm writing autolisp programme for my own use. I've 1 small problem. I don't know the AutoCAD command on how to extract the 9 digit of PCB serial number. The purpose for this is to protect the program it self. I hope somebody can give me the answer. Thank you
Mamy.
Active Contributor
cado
Message 2 of 6 (998 Views)
Re: PC Board Serial Number
11-29-2010 09:13 AM in reply to: JTJSBJB
Hi..
You can use the HD serial number..
(defun HDSERIAL (drv / DrvObj FSO getDRV)
(setq FSO (vlax-create-object "Scripting.FileSystemObject"))
(setq getDRV (vlax-invoke FSO 'GetDrive drv))
(vlax-get getDRV 'SerialNumber)
  (vlax-release-object FSO)
  (vlax-release-object getDRV)
Member
JTJSBJB
Message 3 of 6 (963 Views)
11-30-2010 07:27 AM in reply to: cado
Hi Mr. CADO,
Thanks a lot for your reply on my message and helping me to solve the problem.
I've tried the small lisp that posted by you. Unfortunately it's not work. Maybe my AutoCAD version is not competable with the command.
Active Contributor
cado
Message 4 of 6 (959 Views)
11-30-2010 07:30 AM in reply to: JTJSBJB
sorry....I forgot to put...
 (vl-load-com)
Member
JTJSBJB
Message 5 of 6 (931 Views)
12-02-2010 05:20 AM in reply to: JTJSBJB
Hi Mr. CADO,
It's give me error as below. I've tried for every line in the lisp.
; error: too few arguments
Active Contributor
cado
Message 6 of 6 (925 Views)
12-02-2010 06:19 AM in reply to: JTJSBJB
ok I see...
you need to specify your drive.
examples..
(vl-load-com)
;|    TESTS
(HDSERIAL "c:")
(HDSERIAL "x:")
(HDSERIAL "\\\\Server1\\folderA\\FolderB")
put the (vla-load-com) on the top.
