Visual LISP, AutoLISP and General Customization
path of the added item is too long
7 REPLIES 7
Message 1 of 8
kolasing
5941 Views, 7 Replies
Did anyone else have issues with creating an AutoCAD deployment and "The path of the added item is too long" error message?
I understand that the paths are limited to 255 characters but I tried just a local path and I get the same error.
Under Additional Files in deployment options, I want to add 2 folders under <Installation Directory> and add 2 files under Support folder.
1st folder would be ARG folder for a custom profile xxx.arg file
2nd folder would be Template with a custom template xxx.dwt file
Under Support, I want to browse and add two files: custom accaddoc.lsp and enterprise acad.cuix file.
All of those files reside on a share drive but the paths are about 40 char so I'm way below the limit.
Every time I want to add a folder under <Installation Directory> I receive the error message:
The path of the added item is too long: "Create New Folder" Please limit this path to -28 characters (currently 17).
So I copied all thos files locally but the same error show up.  Is this a bug?  I can't customize my deplyoment if those files are not available. Thanks.
7 REPLIES 7
Message 2 of 8
rkmcswain
in reply to: kolasing
This is not an answer to your issue, but a comment if you're interested.
I create all my deployments straight OOTB, without any customization, to avoid issues like this. Then I post process the install at launch time to handle things like support paths, etc. using a local "one-time" acad.lsp, which in turn loads the network "acad.lsp" and everything else.
Message 3 of 8
johnres
in reply to: rkmcswain
You can use Long Path Tool as well, it works good for such problems.
Message 4 of 8
kc
Did you get an answer to this? As I have struck the same problem 2 years running now on version 2014 and 2015 for Autodesk Inventor. Link to my recent  Post
Regards
Kent
Message 5 of 8
kolasing
in reply to: kc
I haven't experienced this error in Inventor.  However, I do use some custom templates that I place in the directory after the deployment.  This is the template directory: C:\Users\Public\Documents\Autodesk\Inventor 2013\Templates.
Tags (2)
Message 6 of 8
kc
Thanks Kolasing for your reply.
What you discribed you do after installation is exactly what I had to do last year with Design Academy 2014 (Inventor). Putting the files manually into 100 machines is not much fun, I would have thought this bug would have been picked up by now with the release of 2015 as it wasn't present in Design Academy 2013. I have posted a support case so hopefully they sit up and take notice now. 🙂
Regards
Kent
Message 7 of 8
dgorsman
in reply to: kc
Old school is still the best school for simple file management tasks: BAT file.  Can even be run through more modern tools like SCCM so you don't even have to leave your chair.
Message 8 of 8
kc
Hi Kolasing,
I ended up logging a support case and finally got an answer back, see below.
This is actually a defect on the coding of the setup file. For the workaround, please perform below suggestion, you may have copy the content of your media onto a HDD as you'll find the setup.ini is write protected :
1. Create a backup for the setup.ini file.
( How ? You may copy the original setup.ini file and paste it to the same location and name it setupbackup.ini )
2. Once the Setupbackup.ini is created, open the setup.ini and look for :
#================Global MSI Properties=================#
[GLOBAL_MSI_PROPERTIES]
3. Modify this value to look as below :
PATH_LENGTH=182
4. Save the setup.ini file and created the deployment again and it should allow you to choose a path in inventor setup.
I hope this solves your problem.
Regards
Kent
Tags (1)
”Boost
