Visual LISP, AutoLISP and General Customization
paperspace selection sets
10 REPLIES 10
Message 1 of 11
579 Views, 10 Replies
I wish to collect a selection set of blocks in paperspace of a certain name.
For model space I would use the following line:
(setq x1 (ssget "_x" '((2 . "*etc*") (410 . "model"))))
I am stumped when it comes to setting paperspace as the 410 ssget list value
as the name can be modified and I need it to work in all drawings. I tried
setting a variable to the paperspace layout name and using a print function
at the (410 . "model") point but without sucess. I was wondering if someone
can point me in the right direction
Many thanks.
Drew Jarvis
ACDP
10 REPLIES 10
Message 2 of 11
Assuming the variable myLayout contains the name of the layout you are
filtering for:
(setq x1 (ssget "_x" (list (2 . "*etc*") (cons 410 myLayout)))))
check my parens...I didn't test...
Bobby C. Jones
http://www.acadx.com
Message 3 of 11
(cons 410 myLayout)
Drew Jarvis
"Bobby C. Jones" wrote in message
news:52E9F3371B88E76896D632A7205C8080@in.WebX.maYIadrTaRb...
> filtering for:
> Bobby C. Jones
Message 4 of 11
Cliff, *DON'T* try this in VBA 🙂 selection set filters in VBA don't allow
filtering on the 410 group...
Bobby C. Jones
Message 5 of 11
Don't you need to quote the (2 . "*etc*")?
(setq x1 (ssget "_x" (list '(2 . "*etc*") (cons 410 myLayout))))
-Jason
> filtering for:
> Bobby C. Jones
Message 6 of 11
I should have said check *everything*...I didn't test nothing 🙂
Thanks Jason
Bobby C. Jones
Message 7 of 11
(ssget "x" '((0 . "insert")(2 . "*etc*")(410 . "~Model")))
___
"Drew Jarvis" wrote in message
news:84DAE30CE893CB244CDB7D8517FB9E75@in.WebX.maYIadrTaRb...
name.
Message 8 of 11
Using (410 . "~tabname") works, but you can just as easily
use the 67 group, which can be more "efficient".
(ssget "x" '(.... (67 . 1))) ;; 1 = Paper space only
(ssget "x" '(.... (67 . 0))) ;; 0 = Model space only
name.
value
function
someone
> Many thanks.
> Drew Jarvis
> ACDP
Message 9 of 11
msarqui
And how to make the selection set for both model and paper space in the same routine?
Ex.: How to select all hacths in model and paper space?
Message 10 of 11
Kent1Cooper
in reply to: msarqui
You can make a selection set [in AutoLISP terms] of all Hatch patterns in model and paper space easily enough, with:
(ssget "_X" '((0 . "HATCH")))
But you can't have an AutoCAD command "select" and do something with those that are not in the current space.  [See the hatch-to-back thread for a workaround, unless you're asking this for some different reason.]
Kent Cooper, AIA
Message 11 of 11
msarqui
in reply to: Kent1Cooper
Hi Kent,
You answered my question 🙂
I will try to find another way.
Thanks!
”Boost
