Paper Space Viewport seperation
9 REPLIES 9
Message 1 of 10
jmodglin
594 Views, 9 Replies
I am trying to figure out how to seperate the difference between the paper space viewport which is required for a Paper Space Layout and the one which you make. Some of my routines won't work correctly without seperating them (i.e., Viewport Lock). Has anyone found out how to delineate the viewports made by a user and the Paper space viewports required for a PS Layout? Is what I am asking clear?? Joshua Modglin
9 REPLIES 9
Message 2 of 10
in reply to: jmodglin
Check assoc 69.
-Jason
Member of the Autodesk Discussion Forum Moderator Program
you make.
Message 3 of 10
jmodglin
?? They are all coming as "0", except the last user created PViewport is "2" and last Layout PViewport is "1". Thus, I can get the last active User created PViewport but what if I want all the drawing's user created PViewports?? Thanks for the help. Joshua Modglin
Message 4 of 10
(setq ss (ssget "x" '((0 . "VIEWPORT") (-4 . "/=") (69 . 1))))
As far as the zeros are concerned, the viewport id numbers are not set until
the layout has been set current. Maybe that is what is going on?
-Jason
Message 5 of 10
jmodglin
Interesting! (SETQ *DOC* (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT)))
(SETQ CURLAYOUT (VLA-GET-ACTIVELAYOUT *DOC*))
(SETQ LAYOUTS (VLA-GET-LAYOUTS *DOC*))
(SETQ CNT (VLA-GET-COUNT LAYOUTS))
(WHILE (> CNT 0)
(SETQ LAYOUT (VLA-ITEM LAYOUTS (- CNT 1)))
(IF (/= "Model" (VLA-GET-NAME LAYOUT))
(VLA-PUT-ACTIVELAYOUT *DOC* LAYOUT)
(SETQ CNT (- CNT 1))
(VLA-PUT-ACTIVELAYOUT *DOC* CURLAYOUT)
(SETQ SS (SSGET "X" (LIST (CONS 0 "VIEWPORT")(CONS -4 "<>")(CONS 69 1))))
Thanks for the info, Jason! Joshua Modglin
Message 6 of 10
Your welcome. Not sure I follow what you are doing with all of that....
-Jason
Message 7 of 10
jmodglin
As you stated earlier, the layouts have to have been active during the current drawing session for the DXF code 69 to read correctly. All the jargin ahead of the "SSGET" guarantees that. Joshua Modglin
Message 8 of 10
Unless you *have to* stick with ActiveX wouldn't this be easier?
(foreach x (layoutlist) (setvar "ctab" x))
or filter for what has been set current....
(mapcar
'(lambda (x) (if (not (JRP:LayoutActive x)) (setvar "ctab" x)))
(layoutlist)
; Argument: string, the name of a defined layout.
; Return: if the specified layout has been activated T
; is returned, otherwise nil.
; Notes:
; Viewport Id numbers are not assigned until 'that' space is set
; current. Since each layout is a viewport, the following would
; return T if the layout has been set current at least once.
(defun JRP:LayoutActive (Layout / ss)
(if
(setq
ss
(ssget
"x"
(list
'(0 . "VIEWPORT")
'(69 . 1)
(cons 410 Layout)
T
-Jason
Message 9 of 10
I've been trying to find another way to filter the viewports, but the only thing
I can come up with is comparing the numeric values of the handles on the
assumption that the primary viewport is older than any created after within the
same layout, bu I don't know if that can be trusted. Anyone?
John Uhden, Cadlantic/formerly CADvantage
http://www.cadlantic.com
Sea Girt, NJ
"jmodglin" wrote in message
news:f0e3637.5@WebX.maYIadrTaRb...
Message 10 of 10
wkiernan
; LOCKVPS locks all viewports, UNLOCKVPS unlocks all viewports.
; Code derived from comment by jmodglin on Autodesk LISP forum
; http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Paper-Space-Viewport-seperation/m-p/8...
(defun-q C:LOCKVPS()
 (lockvp_sub "on")
 (princ "\nAll viewports locked. ")
 (prin1)
(defun-q C:UNLOCKVPS()
 (lockvp_sub "off")
 (princ "\nAll viewports unlocked. ")
 (prin1)
(defun-q lockvp_sub(arg)
 (setq oldcmd (getvar "cmdecho"))
 (setvar "cmdecho" 0)
 (setq *doc* (vla-get-activedocument (vlax-get-acad-object))
       curlayout (vla-get-activelayout *doc*)
       layouts (vla-get-layouts *doc*)
       cnt (vla-get-count layouts)
 (while (> cnt 0)
  (setq layout (vla-item layouts (- cnt 1)))
  (if (/= "Model" (vla-get-name layout))
   (vla-put-activelayout *doc* layout)
  (setq cnt (- cnt 1))
 (vla-put-activelayout *doc* curlayout)
 (setq ss (ssget "x" (list (cons 0 "viewport")(cons -4 "<>")(cons 69 1)))
       ctab (getvar "ctab")
 (foreach vpname (ss2enl ss)
  (setq vpdata (entget vpname))
  (setvar "ctab" (cdr (assoc 410 vpdata)))
  (command "mview" "lock" arg vpname "")
 (setvar "ctab" ctab)
 (setvar "cmdecho" oldcmd)
1.) I prefer lower-case...
2.) This could be improved by checking the 16384 bit in the 90 group code to see if the viewport is already locked or unlocked as desired, in which case you wouldn't have to touch it, and then by sorting by ctab value so you'd only have to go to each layout tab once even if there were multiple viewports that needed to be changed in it.  But even as is it's going to be a nice time-saver for me.  THANKS!
”Boost
