Hi Folks,
Tried to use the above to do the same in autocad lt 2013, but there is no such file acad.mns
Does anyone know how to do it ?
Many thanks,
Graham
command: CUI
Have a look at the attached image and modify the macro and access lines to your liking...
You will first need to create a new command (bottom-left pane).
Drag and drop this new command into the shortcut area (top-left pane).
Highlight the line you just added in the top-left pane and edit in the bottom-right pane.
Good Luck!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Many thanks for your reply, I appreciate your time. I created a new command called "pan left", dragged it into 'keyboard shortcuts' in the top left pane, clicked on it. In the right pane, where it says keys I changed this to "control left" (by pressing the keys) . The macro reads "^c^c" and I can't figure out what to put here instead. I tried:
^P [Control+"LEFT"]'-pan ^P(trans (list (* 0.25 (getvar "viewsize")) 0) 0 1)
When I try control left in model space it brings up CUI again, I'm quite sure I'm doing the macro wrong, please forgive my ignorance - can you spell it out for me?! Also, is it possible to just use the arrow keys instead of holding control?
Thanks.
Graham
Scot-65
Thanks for that, tried it and it basically does the same as typing -pan in the command line. It says:
Command: -pan Specify base point or displacement: (trans
Requires two points, or a displacement followed by ENTER.
Any ideas? I'd like to figure it out for myself but I dont know what trans etc. means, and I couldn't find a simple guide, how did you learn how to write the code?
Many thanks.
p.s. I tried ^C^c -pan ; 0,0 ; 1000,0
This works, but only effective when zoomed in - I guess I need to do it relative to the current zoom, such as by pixels instead of mm ?
