Visual LISP, AutoLISP and General Customization
Outline Shrinkwrap with islands of crossing closed objects?
6 REPLIES 6
zasanil
877 Views, 6 Replies
I've seen a few outline / shrinkwrap lisps that create a single closed ouline around a set of objects, but I was looking for one that would do the same while creating islands if it detects any inside.
If anyone knows of a lisp that does this please let me know. My searches have come up empty.
Thanks!
Dan Nicholson C.I.D.
PCB Design Engineer
6 REPLIES 6
_gile
in reply to: zasanil
If I do not misunderstand your request, you can find an answer here at TheSwamp (if you do not already have an account, you'll need to register to acces this part of the site). This thread contains .NET (C# and F#) and AutoLISP codes plus a little video which shows the command behavior.
You can also get this LISP named 'Fusion' from this web page (french comments and prompts).
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
zasanil
in reply to: _gile
Hi Gilles,
That lisp worked fine. Thanks for the link! I noticed the discussion in that swamp thread about the speed of the routine. The items I'm trying to process are very numerous and it takes a good 15 minutes or so to process one layer. I have autocad 2013 and I've only ever used lisp scripts, but that thread was talking about the C# version being much faster. It there a way I can load the C# into autocad 2013?
Dan
PCB Design Engineer
_gile
In the attached ZIP file you'd find two DLLs: ShrinkWrapPlines_18.dll (for AutoCAD 2007-2012) and ShrinkWrapPlines_19 (for AutoCAD 2013+).
  • Unzip the DLLs (perhaps you'd have to unblock the DLL)
  • Load the DLL corresponding to you AutoCAD version with the NETLOAD command.
  • Launch UPL command and select the polylines
The command will spend some time to achieve the first time it runs due to the modeler DLL loading (required to create regions) and the final compilation of the DLL.
Anyway, it may be faster to run the command several times selecting only some polylines then run it once with all the polylines in the drawing.
Gilles Chanteau
GileCAD
GitHub
stevor
Zas, other examples in autolisp can be found with searches for: Convex Hull +autolisp.
S
zasanil
Thanks Gilles and Stevor for the file and suggestions. /cheers
PCB Design Engineer
_gile
stevor,
What zasanil seems to want (and what the provided UPL command does) is not at all the same as a convex hull (it's more a concave hull possibly with islands).
Gilles Chanteau
GileCAD
GitHub
”Boost
