What is the osmode bit that toggles off the running snaps... but leaves the underlying user running snaps settings un-effected?
Solved by Kent1Cooper. Go to Solution.
@mdhutchinson wrote:What is the osmode bit that toggles off the running snaps... but leaves the underlying user running snaps settings un-effected?
Yes, it's 16384 [it's right there in Help for the OSMODE System Variable]. The following is effectively the same as hitting F3 to toggle running Osnap on or off [whatever it isn't currently] without changing the combination of modes:
(setvar 'osmode (boole 6 (getvar 'osmode) 16384))
@mdhutchinson wrote:Thanks! That is exactly what I needed.
You're welcome. I didn't look, since I knew a quickie answer, but I suspect the same question has come up here before....
