Visual LISP, AutoLISP and General Customization
*Chalmers, Richard
Message 1 of 2 (88 Views)
orthographic projects in model space
88 Views, 1 Replies
05-23-2002 12:21 AM
I would like to be able to make orthographic views of a 3d solid and have
the projections all land on one plane in model space.
Currently I go through solview, soldraw then rotate the resulting views and
then put them all on one plane. It's tedious. Plus I end up with tons of
layers that are not needed which I have to purge. All I need are three
layers: VIS, DIM and HID.
What would be great is just pick the solid and have the projections all be
made and put onto a plane.
I tried "make2dlight" which I got at Catalog but that didn't work with
AutoCAD2002. I could use MDT but I don't need the parametrics; my solids
are dumb and that's fine.
Any suggestions?
Richard Chalmers
rchalmers@weatherend.com
www.weatherend.com
*Broad, Doug
Message 2 of 2 (88 Views)
Re: orthographic projects in model space
05-23-2002 04:55 AM in reply to: *Chalmers, Richard
Richard,
Have you tried createhlr or aeccreatehlr together with view?
Of course (no hidden lines - hence the hlr part)
Its relatively easy to create a program to throw the hlr views
created by that command in alignment for the basic
orthographic views.
But once you set up a template drawing with the solview
viewports, you can plop any 3dsolid into the model space
and then use soldraw in paper space. The layers are
great because they are viewport specific and with locked
viewports you should have no problems doing the rest
of the work in paper space.
Doug
"Richard Chalmers" wrote in message news:849E6DD8A49D53C6CAA6B0675C07148E@in.WebX.maYIadrTaRb...
> Any suggestions?
> Richard Chalmers
> www.weatherend.com
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
