open DWG´s at the same acad session
1 REPLY 1
devitg
423 Views, 1 Reply
There is a way to get a LIST of all the DWGs open at the actual ACAD session???
1 REPLY 1
in reply to: devitg
In it's simplest form you could use
(defun c:foo ( / docs )
  (vlax-for doc (vla-get-documents (vlax-get-acad-object))
    (setq docs (cons (vla-get-fullname doc) docs))
 Which will result in a full name (with path) for any open (but obviously saved) drawing file. However an unsaved document will return an empty string "".
Depends on what you want to use it for. The other document property(s) that may be of use might be "name" and "path".
”Boost
