Draw line
Change layer to S-3
Offset .33
(pick the side to offset)
Change layer to S-1
Offset (last) .33
(offset to same side)
Change layer to S-3
This is what I have so far:
^C^C-layer;s;S-1;;_line;\\;select;last;;offset;.33;m;\\;;-chprop;p;l;;la;S-3;;
At the first offset command, I get:
Select object to offset or [Exit/Undo] <Exit>:
In order for the macro routine to work, I need to select the "LAST" object. However, Autocad is not recognizing the "LAST" object to be selected. This works when I go step by step, but not as strung together in a macro.
I also have to pick the side to offset twice - is there a way to combine these into one pick?
I found that if I draw the line on the desired layer for the middle object, then CHPROP; previous; last;; this selects the outer two lines (the one originally drawn and the last one offset) and allows me to change the layers.
see the attached .Jpeg for desired results. (Layer S-3 is green, S-1 is red, these layers already exist in the drawing)
Thank you
P.S. I need a macro, not lisp
Solved by m_rogoff. Go to Solution.
Hi m_rogoff,
if your AutoCAD version is not too old, you may also explore the 'Layer' option at OFFSET command...
Try
^C^C-layer;s;S-1;;_line;\\;_OFFSET;.33;@;\;_CHPROP;L;;LA;S-3;;
Hope that helps
Henrique
Henrique,
This is what I came up with. When I used the (Layer) and (Multiple) options within the OFFSET command, it would not select the line drawn as the current object. I have to manually select the line twice ( \\;) at the end of the routine, which is not ideal, but still adequate.
Ultimate goal is 3 lines, outside 2 are layer S-3, middle is layer S-1
^C^C-layer;s;S-3;;_line;\\;_OFFSET;.33;@;\;_CHPROP;L;;LA;S-1;;_OFFSET;L;C;.33;@;\\;
The lisp function vla-Offset should help it offsets to both sides. All you need to select is the middle line.
@TomBeauford wrote:
The lisp function vla-Offset should help ....
... except that they have some Users who use AutoCAD LT and can't do Lisp functions [there's another thread where AutoLISP solutions were suggested, in which we learned that], which is the reason they're aiming for a purely-macro approach [see the end of the first message here].
Perhaps something like this
^C^C-layer;_S;S-3;;_line;\\;-layer;_S;S-1;;_OFFSET;_L;_C;;;;.33;@;_M;\\;^C^C_OFFSET;_L;_S;;;
Hope that helps
Henrique
Or
^C^C-layer;_S;S-3;;_line;\\;-layer;_S;S-1;;_OFFSET;_L;_C;;;;.33;@;_M;\\;^C^C_OFFSET;_L;_S;;;_layerp;_layerp;
to restore also the current layer
Henrique
Wrong layer order...
^C^C-layer;_S;S-1;;_line;\\;-layer;_S;S-3;;_OFFSET;_L;_C;;;;.33;@;_M;\\;^C^C_OFFSET;_L;_S;;;_layerp;_layerp;
Henrique
Henrique,
The code was offsetting the middle line on the source layer, so the middle and outside lines were on the same layer. I modified the end to change prop of the last object to the correct layer instead. Thank you for your help, I couldn't have gotten this without your help.
^C^C-layer;_S;S-3;;_line;\\;-layer;_S;S-1;;_OFFSET;_L;_C;;;;.33;@;_M;\\;^C^C_OFFSET;;;_layerp;_layerp;_Chprop;L;;LA;S-3;;
One more quick question on a very similar macro
^C^C-layer;_S;S-SHR;;_line;\\;_OFFSET;3;@;\\;^C^C_erase;L;;_layerp;_layerp;;^C^C
At the end of the macro, I get a message:
Select object to offset or [Exit/Undo] <Exit>: *Cancel*
I have to manually hit escape to exit out of the command. It also won't delete the first line drawn. Suggestions? Thanks!
@m_rogoff wrote:
Henrique,
Weird, I have tested the code on AC2012 and AC2014, without any problem.
The las command was '-layerp', if user press enter, will call the last command, and change the last two lines to the source layer.
Do this code work ok on your system?
^C^C-layer;_S;S-1;;_line;\\;-layer;_S;S-3;;_OFFSET;_L;_C;;;;.33;@;_M;\\;^C^C_layerp;_layerp;_OFFSET;_L;_S;;;
For the other macro, I'll see what I can do... (I don't have AutoCAD on this laptop)
Henrique
Can you explain in words what are you trying to do.
You are setting the layer S-SHR as current, draw a line, offset the line 3 units, pause twice? erase the 'offsetted' line? call 'layerp' command twice? and cancel...
Henrique
For this routine, I want to draw a line on layer S-SHR, offset 3" (user pick side) then delete the original line. You are left with 1 line, 3" from where it was drawn. I got it to do everything correct but deletes the offset object, not the line drawn. Selecting LAST Object (L) does not work.
^C^C-layer;_S;S-SHR;;_line;\\;_OFFSET;3;@;\;_erase;L;;_layerp;;
Thanks for your help
