Visual LISP, AutoLISP and General Customization
Object Selection based on type/layer
1 REPLY 1
faugustom
300 Views, 1 Reply
Hi LISP guys!
I need your help for creating a code to select some objects based on it's type and layer, just like the QuickSelect command... there are two cases:
1. I want to select all the objects in the layer "X" an then apply a command;
2. I want to select all the lines (for example) in the layer "Y" an then apply a command;
and I need these action to be cumulative... execute action various times (each one with different parameters...)
Can someone help me with a code?
Thanks'
Fernando
1 REPLY 1
in reply to: faugustom
You can try to use Entlasel routine. After, use the previous selection to apply a command.
Rogerio
”Boost
