Try it putting your replace path in quotes, too.
^C^C-XREF;P;"Arch-E LEG COL PROJ";"F:\projects\Jordan River
1\Drawings-Sheets\X-refs\30X42 TITLE (LA).dwg";
wrote in message news:5609853@discussion.autodesk.com...
I'm trying to use a macro to change the path of an xref. I have it all
working manually, but when I use is as a macro it says that is cannot find
the file in the support path. Here is the Macro. can anyone tell me what
I'm doing wrong?
^C^C-XREF;P;"Arch-E LEG COL PROJ";F:\projects\Jordan River
1\Drawings-Sheets\X-refs\30X42 TITLE (LA).dwg;
Arch-E LEG COL PROJ is the xref Name
"F:\projects\Jordan River 1\Drawings-Sheets\X-refs\30X42 TITLE (LA).dwg"
is the new path.
thanks
