Visual LISP, AutoLISP and General Customization
No. of blocks to text
1 REPLY 1
herreraj13
158 Views, 1 Reply
I’m looking for a way to count the number of blocks in a drawing by clicking on the block and output it to text in the drawing. I’m trying to make a schedule that lists the parts and the quantity. I’m using the TABLE command to make the schedule and found a FIELD that allows you to click on the block and it displays the block name in the cell. Is there not a simple way of getting the count like you can get the name? I don’t care if it is DIESLE/FIELD command or a LISP, I just need to get the count to text somehow.
I've tried searching thru the post for the answer but can not seem to find it. The closest I can find is displaying the amount in the command line. I am using 2005.
John
1 REPLY 1
in reply to: herreraj13
(sslength (ssget "X" '((0 . "INSERT")(2 . "YourBlockNameHere"))))
....or something like that should work.
wrote in message news:5228839@discussion.autodesk.com...
I'm looking for a way to count the number of blocks in a drawing by clicking
on the block and output it to text in the drawing. I'm trying to make a
schedule that lists the parts and the quantity. I'm using the TABLE command
getting the count like you can get the name? I don't care if it is
somehow.
am using 2005.
John
”Boost
