Reid,
I recently found this problem as well, with running (command) functions within
acaddoc.lsp.
The problem I ran up against was that I could not enter a viewport in a layout
by double-clicking inside of it.
To test this, I made a template with a layout, and put a Viewport in it. Using
that when creating a new drawing, with (command) inside of the acaddoc.lsp, and
I was unable to enter the viewport by dbl-click. Hitting the MSpace button does
work.
Curiously, starting a second drawing using the same template, and everything is
OK.
FWIW, the (command) calls were made inside of S::STARTUP. When these are
commented out, everything runs fine.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
On Tue, 4 Apr 2006 15:17:54 +0000, Reid M. Addis
wrote:
>This is particular to ADT, and may not effect AutoCAD only.
>It IS a real problem however. Thanks everyone.
