Hi guys,
I don't use AutoCad so much, in fact I have been hopeless for a while with the new interface, but steadily I'm getting there.
It seems with 2010 onwards the area command doesn't work on plines. So that means the famous tlen.lsp doesn't work anymore. I have tried to play around with it myself, but just can't get it to work. (Don't have any experience with lisp). I've tried using the lengthen command instead, but I can't get it to work either.
The current lsp is:
(defun C:TLENG (/ ss tl n ent itm obj l)
(setq ss (ssget)
tl 0
n (1- (sslength ss)))
(while (>= n 0)
(setq ent (entget (setq itm (ssname ss n)))
obj (cdr (assoc 0 ent))
l (cond
((= obj "LINE")
(distance (cdr (assoc 10 ent))(cdr (assoc 11 ent))))
((= obj "ARC")
(* (cdr (assoc 40 ent))
(if (minusp (setq l (- (cdr (assoc 51 ent))
(cdr (assoc 50 ent)))))
(+ pi pi l) l)))
((or (= obj "CIRCLE")(= obj "SPLINE")(= obj "POLYLINE")
(= obj "LWPOLYLINE")(= obj "ELLIPSE"))
(command "_.area" "_o" itm)
(getvar "perimeter"))
(T 0))
tl (+ tl l)
n (1- n)))
(alert (strcat "Total length of selected objects is " (rtos tl)))
(princ)
Can someone guide me please.
Thanks.
Ozitag
Solved by Kent1Cooper. Go to Solution.
