Thank you, had a brain fart....all is working now...
"David Bethel" wrote in message
news:03FE88ACA03819273F85DD3F5530FA70@in.WebX.maYIadrTaRb...
> It is the syntax that your are using this incorrect
> (* 3 4) = 12
> (- (* 3 4) (* 2 2)) = 3
> (/ (- (* 3 4) (* 2 2)) (* 2 5)) = 0.3
> We are a function 1st language.
> -David
> "Thomas D. Wooton" wrote in message
> news:6ADF11CAFBED7443EE1F2155569B22C0@in.WebX.maYIadrTaRb...
> > I have written a lisp routine to pull out the x and y of line segments
and
> > set them to specific variables to be used in a formulas.
> > These are the variables....
> > x1 = x for the start point of a line1
> > y1 = y of the start point of a line1
> > x2 = x of the end point of a line1
> > y2 = y of the end point of a line1
> > x3 = x of the start point of line 2
> > y3 = y of the start point of line 2
> > x4 = x of the end point of line 2
> > y4 = y of the end point of line 2
> > (setq ua
> > (((x4-x3)(y1-y3))-((y4-y3)(x1-x3)))/(((y4-y3)(x2-x1))-((4-x3)(y2-y1))))
> > It errors at the calculation of (x1-x3) which returns a negative value
The
> > program errors and gives me a "no function definition" error. Will lisp
> > calculate a formula with negative values? Is this the problem? How can
you
> > get lisp to calculate a formula with positive and negative numbers in
the
> > formula? Here is the formula:
> > This formula will give me a variable I need for another formula to find
> the
> > intersection point of these two lines.
> > intersectionx = x1 + ua(x2-x1)
> > intersectiony = y1 + ua(y2-y1)
> > End result is this. I am trying to find how the weight is distributed on
> > each end of a beam. Using a weight, and moment of inertia, I can
calculate
> > the force, and input it in automatically at the support locations by
> > inputting text to the coordinated I already have for the supports. But I
> > can't get lisp to work with negative numbers in formulas.
> > Any assistance would be appreciated.
> > Thomas D. Wooton
> > Southern Systems Inc
