I have the value for this either negative or Positive it sould it is not negative Value.
(setq Depth (getreal "\nEnter the Depth of the Duct..= "))
Not sure from your question.
If you dont want negative value and zero use this line before getreal
(initget (+ 2 4))
More info initget
(initget (+ 2 4))
(setq Depth (getreal "\nEnter the Depth of the Duct..= "))...
And if you use (getdist) instead of (getreal), the User will have the choice of whether to give that distance by entering a number as for (getreal) or picking two points on-screen. And if entering a number, they can use any valid distance format including those that (getreal) will not accept, for instance if they use imperial units, they can enter a distance in feet and inches and fractions, decimal feet, etc. [The option is only for the input format -- in all cases a real number will be returned.]
