Valued Contributor
1 Kudo
Post 1 of 4
Need lisp to change layer of all nested objects
455 Views, 3 Replies
04-17-2014 10:30 AM
Howdy, I am looking for a lisp routine to add to search selected block/blocks to find any objects on layer "A-EquipLwr" and have them changed to layer "-PATT". Both layers are existing in the dwg, all the blocks have only 2 layers contained in them (A-EquipLwr and 0), but there are multiple variations of the block for different purposes. Does anyone have a lisp that will do this layer change in 1 step?  Thank you in advance.
Note: I want to keep the layer name as it is, since it is connected to other objects in the drawing which are not a part of blocks.
^C^CMoonwalk
Try the following quickly written code:
(defun c:fixblocks ( / a b f i l s )
(setq a "A-EQUIPLWR"
b "-PATT"
(defun f ( n / e x )
(if (and (not (member n l)) (setq e (tblobjname "block" n)))
(progn
(setq l (cons n l))
(while (setq e (entnext e))
(if (= (strcase a) (strcase (cdr (assoc 8 (setq x (entget e))))))
(entmod (subst (cons 8 b) (assoc 8 x) x))
(if (= "INSERT" (cdr (assoc 0 x))) (f (cdr (assoc 2 x))))
(if (setq s (ssget '((0 . "INSERT"))))
(repeat (setq i (sslength s))
(f (cdr (assoc 2 (entget (ssname s (setq i (1- i)))))))
(command "_.regen")
(princ)
Due to the recursive nature of the code, the above should also account for nested blocks, nested to any depth.
335 Kudos
Post 2 of 4
Re: Need lisp to change layer of all nested objects
04-17-2014 11:21 AM in reply to: ksmith84
          b "-PATT"
            (progn
                (setq l (cons n l))
    (command "_.regen")
    (princ)
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
Valued Contributor
1 Kudo
Post 3 of 4
04-17-2014 11:30 AM in reply to: Lee_Mac
It works like a charm! Thank you once again Lee! It seems I've got more code studying to do haha.
^C^CMoonwalk
335 Kudos
Post 4 of 4
04-17-2014 11:44 AM in reply to: ksmith84
Excellent to hear! - You're most welcome ksmith :smileyhappy:
Expert Elite
