Visual LISP, AutoLISP and General Customization
need lisp that will sum selected text values
15 REPLIES 15
Message 1 of 16
9983 Views, 15 Replies
Can someone steer me to a way in autocad (2002) or to a lisp routine that will add together the values of text entities? For instance, if I have a big parking lot and each section is labeled with the number of spaces, I could pick the texts and it would add all the numbers together to give me a total. Right now I export to excel to do this. I have quite a few situations where this would be handy, not just for parking spaces, so I really just want a lisp that will add all my selected numbers. Mtext or Dtext. Thanks!
15 REPLIES 15
Message 2 of 16
I came up with this one a couple of years ago, it still works for me.
(defun c:calc()
(initget "+ - * /")
(setq app(getkword "\nWhat application would you like to do:\(+,-,*,/)"))
(if(or (= app "-")(= app "/"))(princ "\nDon't forget order counts. So pick carefully."))
(princ "\nSelect numbers to calculate:")
(setq cal(ssget '((0 . "TEXT"))))
(setq n 0)
(setq l(sslength cal))
(while(/= l n)
(get_info)
(if(= nu3 0.0)
(progn
(ssdel (ssname cal n) cal)
(setq l(- l 1))
(setq n(- n 1))
(setq n(+ n 1))
(setq n 0)
(cond
((= app "+")
(addc))
((= app "-")
(subc))
((= app "*")
(multc))
((= app "/")
(divdc))
(initget "Replace Write")
(princ "\nAnswer= ")
(princ nu5)
(setq tx1(getkword"\nWhat do you want do with the answer\(Replace, Write to screen):"))
(cond
((= tx1 "Replace")
(setq tx2(ssget '((0 . "TEXT"))))
(setq n 0)
(setq l(sslength tx2))
(while(/= n l)
(setq tx3(entget(ssname tx2 n)))
(setq tx4(subst(cons 1 (rtos nu5 2 1))(assoc 1 tx3) tx3))
(entmod tx4)
(setq n(+ 1 n))
((= tx1 "Write")
(setq nu5(rtos nu5 2 1))
(command "layer" "m" "sr_text_n" "c" "3" "" "")
;(command "textstyle" "sr-romands2")
(princ "\nPick point for text insertion")
(command "text" "j" "m" pause "" "" nu5 )
(princ)
(defun get_info()
(setq nu1(entget (ssname cal n)))
(setq nu2(cdr(assoc 1 nu1)))
(setq nu3(atof nu2))
(defun addc()
(get_info)
(setq nu4 nu3)
(setq n(+ 1 n))
(while(/= l n)
(get_info)
(setq nu5(+ nu4 nu3))
(setq nu4 nu5)
(setq n(+ 1 n))
(defun subc()
(get_info)
(setq nu4 nu3)
(setq n(+ 1 n))
(while(/= l n)
(get_info)
(setq nu5(- nu4 nu3))
(setq nu4 nu5)
(setq n(+ 1 n))
(defun multc()
(get_info)
(setq nu4 nu3)
(setq n(+ 1 n))
(while(/= l n)
(get_info)
(setq nu5(* nu4 nu3))
(setq nu4 nu5)
(setq n(+ 1 n))
(defun divdc()
(get_info)
(setq nu4 nu3)
(setq n(+ 1 n))
(while(/= l n)
(get_info)
(setq nu5(/ nu4 nu3))
(setq nu4 nu5)
(setq n(+ 1 n))
Tim
Message 3 of 16
Thanks! I'll give it a go... "T.Willey" wrote in message news:6593832.1086189667449.JavaMail.jive@jiveforum2.autodesk.com... > I came up with this one a couple of years ago, it still works for me. > > (defun c:calc() > > (initget "+ - * /") > (setq app(getkword "\nWhat application would you like to do:\(+,-,*,/)")) > (if(or (= app "-")(= app "/"))(princ "\nDon't forget order counts. So pick carefully.")) > (princ "\nSelect numbers to calculate:") > (setq cal(ssget '((0 . "TEXT")))) > (setq n 0) > (setq l(sslength cal)) > (while(/= l n) > (get_info) > (if(= nu3 0.0) > (progn > (ssdel (ssname cal n) cal) > (setq l(- l 1)) > (setq n(- n 1)) > ) > ) > (setq n(+ n 1)) > ) > (setq n 0) > (setq l(sslength cal)) > (cond > ((= app "+") > (addc)) > ((= app "-") > (subc)) > ((= app "*") > (multc)) > ((= app "/") > (divdc)) > ) > (initget "Replace Write") > (princ "\nAnswer= ") > (princ nu5) > (setq tx1(getkword"\nWhat do you want do with the answer\(Replace, Write to screen):")) > (cond > ((= tx1 "Replace") > (setq tx2(ssget '((0 . "TEXT")))) > (setq n 0) > (setq l(sslength tx2)) > (while(/= n l) > (setq tx3(entget(ssname tx2 n))) > (setq tx4(subst(cons 1 (rtos nu5 2 1))(assoc 1 tx3) tx3)) > (entmod tx4) > (setq n(+ 1 n)) > ) > ) > ((= tx1 "Write") > (setq nu5(rtos nu5 2 1)) > (command "layer" "m" "sr_text_n" "c" "3" "" "") > ;(command "textstyle" "sr-romands2") > (princ "\nPick point for text insertion") > (command "text" "j" "m" pause "" "" nu5 ) > ) > ) > > (princ) > > ) > > > > (defun get_info() > (setq nu1(entget (ssname cal n))) > (setq nu2(cdr(assoc 1 nu1))) > (setq nu3(atof nu2)) > ) > > (defun addc() > (get_info) > (setq nu4 nu3) > (setq n(+ 1 n)) > (while(/= l n) > (get_info) > (setq nu5(+ nu4 nu3)) > (setq nu4 nu5) > (setq n(+ 1 n)) > ) > ) > > (defun subc() > (get_info) > (setq nu4 nu3) > (setq n(+ 1 n)) > (while(/= l n) > (get_info) > (setq nu5(- nu4 nu3)) > (setq nu4 nu5) > (setq n(+ 1 n)) > ) > > ) > > > (defun multc() > (get_info) > (setq nu4 nu3) > (setq n(+ 1 n)) > (while(/= l n) > (get_info) > (setq nu5(* nu4 nu3)) > (setq nu4 nu5) > (setq n(+ 1 n)) > ) > ) > > > (defun divdc() > (get_info) > (setq nu4 nu3) > (setq n(+ 1 n)) > (while(/= l n) > (get_info) > (setq nu5(/ nu4 nu3)) > (setq nu4 nu5) > (setq n(+ 1 n)) > ) > ) > > > Tim
Message 4 of 16
Hai..
      I am very sorry to say it is not working in Autocad2008
Message 5 of 16
pbejse
Maybe you are using Mtext with formatting
Message 6 of 16
Mr Willy
          I could find what i want. but it is not working. The error is - Select objects:  ; error: bad argument type: lselsetp nil.  please rectify this code for me. Iam using Autocad2008. It will very usefull to me. Thank you.
Message 7 of 16
pbejse
That means incorrect Data type. So.. agaim, are you using MTEXT?
Message 8 of 16
Kent1Cooper
@Anonymous wrote:
Can someone steer me ... to a lisp routine that will add together the values of text entities?....
Another approach:
http://cadtips.cadalyst.com/list/sum-values-text-strings
I don't see anything in the description that mentions Mtext, and I haven't downloaded it, so it may also work only with Text entities.
Kent Cooper, AIA
Message 9 of 16
Kent1Cooper
Message 10 of 16
pbejse
in reply to: Kent1Cooper
Exactly my point. as the error mesage indicate as such
This is me short of tellimg the OP  his trying to use the porogram with Mtext entities, but apparently the OP directing the question to the orignal author of the code.
Oh well,..
Nice tip BTW
Message 11 of 16
alanjt_
in reply to: pbejse
Message 12 of 16
in reply to: alanjt_
Message 13 of 16
Tim,
Works great, but where in the lsp could I change the rounding precision of the final number. The numbers I am selecting are all rounded to the second decimal place (which I want), BUT the sum number the lsp is givinf me is rounded to the fisrt decimal place (which I would like to change to the second). Thanks
Message 14 of 16
Kent1Cooper
@Anonymous wrote:
.... where in the lsp could I change the rounding precision of the final number. ... the sum number the lsp is givinf me is rounded to the fisrt decimal place (which I would like to change to the second). ....
[In case Tim's not still checking in after 8-1/2 years....]
Change the last number in the (rtos) functions such as (rtos nu5 2 1) from a 1 to a 2 -- that's the number of decimal places [see (rtos) in the AutoLISP Reference].
Kent Cooper, AIA
Message 15 of 16
braudpat
Hello
An other solution which can read Text & MText entities ...
This routine (TOTTXT) comes froma French forum but I don't remender the Author : SORRY !
Bye, Patrice
;; Routine TOTTXT.LSP
;; Fonctionne en principe sur les TEXT & MTEXT de type numerique
;; Version 1.1 avec Creation d un texte du Total
(defun c:tottxt (/ doc sel tot pt)
  (vl-load-com)
  (setq	tot 0
	doc (vla-get-activedocument (vlax-get-acad-object))
  (princ "\nSélectionnez les textes")
  (if (ssget (list (cons 0 "TEXT,MTEXT")))
    (progn
      (vlax-map-collection
	(setq sel (vla-get-activeselectionset doc))
	'(lambda (x)
	   (setq tot (+ (atof (vla-get-textstring x)) tot))
      (vla-delete sel)
      (if (setq pt (getpoint "\nPositionnez le résultat: "))
	(vla-addText
	  (vla-get-ModelSpace doc)
	  (rtos tot)
	  (vlax-3d-point pt)
	  (getvar "TEXTSIZE")
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 16 of 16
inz.romaniuk
in reply to: braudpat
do we can adapt this list to value of attribute in block ??
”Boost
