Visual LISP, AutoLISP and General Customization
Need help loading a particular net assembly
4 REPLIES 4
e.g.
298 Views, 4 Replies
Hello everybody,
I need a little bit of help because I don't know how to program in lisp. I have a master lisp routine that runs when Autocad is opening. I have some computers running Autocad 2010 and others with Autocad 2012 and from the master lisp routine (which is the same) I need to load a net assembly (one for Autocad 2010 or another for Autocad 2012).
I was thinking to query for Autocad version and if it is Autocad 2010, then load the first dll, or if it is Autocad 2012 then load the second dll, but I don't know how to do this in lisp.
Thank you very much for your help.
e.g.
4 REPLIES 4
hmsilva
in reply to: e.g.
(if (Equal (getvar "ACADVER") "18.s (LMS Tech)" );AC2012
  (load "Ac2012xxxxx.dll")
    ); if not, do not do anything
(if (Equal (getvar "ACADVER") "18.0s (LMS Tech)" );AC2010
  (load "Ac2010xxxxx.dll")
Hope that helps
Henrique
e.g.
in reply to: hmsilva
Yes, thank you very much.
e.g.
hmsilva
in reply to: e.g.
You're welcome, e. g.
EDITED
e. g. wrote:
...I need to load a net assembly..
Sorry, I have read too fast!!!
(if (and (Equal (getvar "ACADVER") "18.s (LMS Tech)") ;AC2012
	 (findfile "Ac2012xxxxx.dll")
  (vl-cmdf "netload" "Ac2012xxxxx.dll")
(if (and (Equal (getvar "ACADVER") "18.0s (LMS Tech)") ;AC2010
  (vl-cmdf "netload" "Ac2010xxxxx.dll")
Henrique
hmsilva
in reply to: e.g.
and a typo
where is "18.s (LMS Tech)"  should be "18.2s (LMS Tech)" for AC2012
Henrique
”Boost
