Excellent, thank you. This place never ceases to amaze me.
Mark
wrote in message news:5271829@discussion.autodesk.com...
If I understand you right, your trying to do something like the side input
of the offset command. I do something similar in my routine that draws A/C
pads. The solution I found is to calculate the 'signed area' (you can do a
search to get a description of what that means). I've attached the main
function I use. The value it returns is positive for one side, and negative
for the other.
In your example you would use it like this:
(SETQ signed_area (#trg_parea (list A B Y)))
And the
n test if the value for signed_area is positive or negative.
