One problem I see is that your circle won't be located at the intersection
of the lines unless they're perpendicular to each other, and your pick
points are precisely on the lines. You're trying to do an awful lot with a
selection of points which are, at best, somewhat arbitrary (no checking to
ensure that they even lie on the lines in question). You might have more
success if you avoided using (command) and analyzed the lines for their
endpoints, then use the (inters) function to find the intersection or
extended intersection, and go from there.
___
"Peter Friedrich"
wrote in message
news:D8D71B94634295A3BB63B272C203B069@in.WebX.maYIadrTaRb...
> ;; this routine fails-- why??
