I'm trying to make selection set of objects I create with ncopy, but can't lisp well enough to manipulate the selection set...
(defun c:ncc ()
(prompt "\select nested object(s) for copying to current layer")
(setq set1 (ssget "_:N" ||.......as i get into ncopy chain with ssget "_:N", the further settings applied here should be: Settings/Insert/(pause to select objects)/0,0,0/@||
(command "laycur" set1 "")
(command "chprop" set1 "" "lt" "bylayer" "c" "bylayer" "lw" "bylayer" "")
(princ)
thanks,
Robert
To simplify my question, I'd like to have this for multiple new objects:
(defun c:ncc ()
(command "ncopy" "s" "i" "\\" "" "0,0,0" "@")
(command "laycur" "l" "")
(command "chprop" "l" "" "lt" "bylayer" "c" "bylayer" "lw" "bylayer" "")
(princ)
