*vianello, davide
Message 1 of 4 (357 Views)
mysql
357 Views, 3 Replies
12-12-2001 06:39 PM
hi
Has anyone tried to connect with MySQL database?
Any help or suggestion is appreciated.
thank you in advance
Davide
*Young, Darren J.
Message 2 of 4 (357 Views)
Re: mysql
12-12-2001 10:44 PM in reply to: *vianello, davide
In article <8E738CA5E6BAD90DD0B6F6A71FF9350B@in.WebX.maYIadrTaRb>,
jmpdvi@tin.it says...
> hi
Try the connectivity group. There's a couple folks there (Jn Fleming &
Scott McFarlane) that are very good with databases.
Sincerely,
Darren J. Young
Minnesota CADWorks, Inc.
P.O. Box 7293
Saint Cloud, Minnesota 56302-7293
Phone: (320) 654-9053
WWW: http://www.mcwi.com
Active Member
rbigger
Message 3 of 4 (357 Views)
Re: mysql
09-28-2006 11:21 AM in reply to: *vianello, davide
I found a way to connect to a mysql database with vlisp. first i installed the ODBC mysql driver from the mysql website. then i created a vlisp command to connect to the dll and run a query. here's an example of the code i wrote.
(vl-load-com)
(defun mysqlQuery (sQuery / $acad dbConn dbConnString dbResult field item)
;connect to autocad application object
(setq $acad (vlax-get-acad-object))
;connect to the mysql dll object
(setq dbConn (vla-GetInterfaceObject $acad "ADODB.Connection"))
;open the mysql database
(setq dbConnString (strcat "DRIVER={MySQL ODBC 3.51 Driver}; SERVER=localhost;"
"DATABASE=mydb; UID=myid; PWD=mypassword; OPTION=3")
(vlax-invoke dbConn "Open" dbConnString)
;run a query on the database
(setq dbResult (vlax-invoke dbConn "Execute" sQuery))
;find the field, item, and value of the first object in the recordset
(setq field (vlax-get-property dbResult "Fields"))
(setq item (vlax-get-property field "Item" 0))
(setq value (vlax-get-property item "Value"))
;release the autocad application and mysql object
(vlax-invoke-method dbConn "Close")
(vlax-release-object dbConn)
(vlax-release-object $acad)
;prompt the result
(prompt (vlax-variant-value value))
(princ)
to run the command i have to send an sql query.
(mysqlQuery "SELECT name FROM staff WHERE name LIKE '%Smith%'")
Active Member
cpambo
Message 4 of 4 (243 Views)
Re: mysql
06-08-2012 10:17 PM in reply to: *vianello, davide
It works!
However, the data returned is only for one row.  Could you show how to get multiple rows (or records)?
Thanks in advance!
