Mtext Rotate To Line
5 REPLIES 5
zootango
5987 Views, 5 Replies
Anyone have a lisp routine that will rotate Mtext to the same angle as the angle of a selected line and the allow you to place the mtext object where you wish.
I know there is an lisp out there called RTL that will allow you to do this with regular or Dtext, but I will not work with Mtext.
5 REPLIES 5
Ajilal.Vijayan
in reply to: zootango
Try this.
I modified the code from here
http://www.cadtutor.net/forum/showthread.php?11844-rotate-text-to-align-line&s=15f9ebab58e8b768ffd9f...
;;  Text Rotated to the selected object angle
(defun c:TRA() (c:TextRotate2Angle))
(defun c:TextRotate2Angle (/ ss lst pt ang obj
                  get_pt_and_angle )
  (vl-load-com)
  ;;  User selection of curve object
  ;;  return pick point & average angle of curve at pick point
  (defun get_pt_and_angle (prmpt / ent p@pt parA parB pt ang)
    (if (and (setq ent (entsel prmpt))
             (not (vl-catch-all-error-p
                    (setq pt (vl-catch-all-apply
                               'vlax-curve-getClosestPointTo
                               (list (car ent) (cadr ent))
      (progn
        (setq ent  (car ent)
              p@pt (vlax-curve-getParamAtPoint ent pt)
              parA (max 0.0 (- p@pt 0.05))
              parB (min (+ p@pt 0.05) (vlax-curve-getEndParam ent))
              ang (angle (vlax-curve-getPointAtParam ent parA)
                         (vlax-curve-getPointAtParam ent ParB)
        (list pt ang)
  ;;  Get Text to align & object to alignment angle
  ;;  Text is not moved, just rotated to the alignment angle
  ;;  Object must have curve data
  (prompt "\nSelect text object to align.")
  (if (and (or (setq ss  (ssget "_+.:E:S" '((0 . "Text,Mtext"))))
               (prompt "\n**  No Text object selected.  **"))
           (or (setq lst (get_pt_and_angle "\nSelect point on object to label."))
               (prompt "\n**  Missed or no curve data for object."))
    (progn
      (setq pt  (car lst)
            ;; ang (FixTextAngle (cadr lst))
            ang (cadr lst)
            obj (vlax-ename->vla-object (ssname ss 0))
      (vla-put-rotation Obj ang)
	  (vla-put-InsertionPoint Obj (vlax-3D-point pt))
  (princ)
zootango
in reply to: Ajilal.Vijayan
Thanks ajilal, just what I needed.
bhull1985
Please click the "Accept as solution" button if your issue was solved by the post.
Just lets the browsers know what needs to be worked on still and what's already been finished.
Plus it gives ajilal a little bit of recognition for producing the code for you to use..
Please use code tags and credit where credit is due. Accept as solution, if solved. Let's keep it trim people!
FSJ_Mo
in reply to: bhull1985
you can use the "TORIENT" command, I have an alias of rt (rotate text) set in my pgp file.
dcasciano3
in reply to: FSJ_Mo
True solution right here. LISP for something so straightforward? come on!
Though, I must assume it didn't work with MTEXT as stated, back in 2013.
”Boost
