MTEXT Column property
6 REPLIES 6
jfboyer
2004 Views, 6 Replies
I can't find how to retrieve/change the Column property (?) of an MTEXT, i.e switching from dynamic to none
Jf
6 REPLIES 6
in reply to: jfboyer
Its just below the Style name of the Text Formatting title box for mtext. If you don't have to title box, right click in the edit box and look for the editor settings.
jfboyer
Thanks azrdgldr, actually I need to do this in vlisp. But I don't think it's possible, the ColumnsType property is exposed only in .NET, unless I'm mistaken
Not saying this would work but have you looked into the dxf codes settings of Mtext.
jfboyer
the Mtext has a Xdata, see below, but for some reason (entget Ename '("*")) failed to retrieve this Xdata
1001
ACAD
1000
ACAD_MTEXT_COLUMN_INFO_BEGIN
1070
75
... etc ...
1000
ACAD_MTEXT_COLUMN_INFO_END
beats me
Jf
Azarko
need to add dxf group of 75 '(75 . 0)
(defun C:TEST ()
  (and
    (setq mtext (car(entsel "\nSelect Mtext to change columns type: ")))
    (setq lst (entget mtext))
    (= (cdr(assoc 0 lst)) "MTEXT")
    (setq lst (if (assoc 75 lst)
		      (subst (cons 75 0) (assoc 75 0) lst)
		      (append lst (list(cons 75 0)))
    (entmod lst)
  (princ)
Jedimaster
Adding the DXF code changes the column type. I cannot select the mtext globally. Is  DXF code 75 some sort of XDATA?
”Boost
