Visual LISP, AutoLISP and General Customization
Mtext background lisp problem
8 REPLIES 8
Message 1 of 9
1038 Views, 8 Replies
I have a routine, developed for me through this forum, that selects text or mtext, converts to mtext if not already, and puts a background mask with 1.1 border. I was using it fine in Map 3D 2007, but have recently switched to Civil 3D 2012 where it does not work. I get this error message:
; error: no function definition: VLAX-ENAME->VLA-OBJECT
The lisp routine is attached.
Why does this not work in 2012? Can someone help me to get it to work?
8 REPLIES 8
Message 2 of 9
Are you trying to use this on the label styles or just regular text or mtext in Civil 3D?  The label styles in Civil 3D have the option of using a background mask or not, you just have to set it in your label styles.  HTH
Message 3 of 9
alanjt_
Add (vl-load-com) to the top of the code.
Message 4 of 9
in reply to: alanjt_
Good catch, I didn't look at the code.  I read a post in the Civil 3D forum that was trying to that to labels and no go.
Message 5 of 9
alanjt_
LoL, apparently I modified it for someone, at some point in time.
Message 6 of 9
Thanks, that worked. Why did it work before, and not before I made the suggested changes?
Message 7 of 9
alanjt_
Some other piece of code or the startup file must have loaded the ActiveX functions. It only has to be executed once per cad session. I keep it in my startup file.
Message 8 of 9
Shneuph
Congrats on the end of summer.  haha.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 9 of 9
What can it be when (vl-load-com) doesn´t do the trick?
All my lisps work just fine.. and then they don´t. So I have to reinstall autocad to have them working again, and this every week. It works for a while than it starts getting this error message again (; error: no function definition: VLAX-ENAME->VLA-OBJECT).. I searched every where in the web and still couldn´t find the answer to this. I don´t know if this helps, but all lisps I use are related to area command.
Please help!!!
”Boost
