vla-put-insertionpoint seems to work. I'm sure
you could do it with vanilla lisp as well, although
I haven't tried.
(setq obj (vlax-ename->vla-object (car (nentsel))))
(setq pt (vlax-3d-point (getpoint)))
Command: (vla-put-insertionpoint obj pt)
nil
then regen or update the object.
-Jason
Member of the Autodesk Discussion Forum Moderator Program
"hutch" wrote in message news:f184b0c.-1@WebX.maYIadrTaRb...
> How can I move dimension text with lisp.
> I tried the attached but can't seem to get it to work.
> Help!
> If this method can not be used is there a way to access the grip node and move through a grip edit programatically?
