Visual LISP, AutoLISP and General Customization
move all 3.5mm text to layer text3.5
10 REPLIES 10
Message 1 of 11
warrentdo
860 Views, 10 Replies
Hello, We are using autocad 2012.
Is there a way to move all 3.5mm text to layer text3.5 and move all 5mm text to layer text5.
I was hoping in a lisp rather than Qselect.
Any pointer would be great.
Regards
Warren.
10 REPLIES 10
Message 2 of 11
phanaem
in reply to: warrentdo
Try this
(defun C:TEST ( / dmz lay e l)
  (setq dmz (getvar 'dimzin)
        lay (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
  (setvar 'dimzin 8)
  (if
    (setq ss (ssget '((0 . "TEXT,MTEXT"))))
    (repeat (setq i (sslength ss))
      (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i))))
            l (strcat "text" (rtos (vla-get-height e) 2)))
      (if (not (tblsearch "Layer" l)) (vla-Add lay l))
      (vla-put-Layer e l)
  (setvar 'dimzin dmz)
  (princ)
Message 3 of 11
pbejse
another
(defun c:test2 (/ ss f on ob)
	(repeat (sslength ss)
          	(if (setq f (assoc
                              (cdr (assoc
                                  40 (setq on (entget (setq ob (ssname ss 0))))
                                ) '((3.5 "Text3.5")(5.0 "Text5.0"))))
                  	(entmod (subst (cons 8 (cadr f)) (assoc 8 on) on)
          (ssdel ob ss)
          )(princ)
we may need to add a fuzz value in case where the text height is NOT exactly 3.5 (i.e. 3.502)
HTH
Message 4 of 11
pbejse
in reply to: pbejse
with fuzz
(defun c:test3 (/ ss f on ob lay)
          	(setq  f (cdr
                      (assoc 40
		(if (setq lay
	          	(cond
	                  ((equal f 3.5 0.01)  "Text3.5")
	                  ((equal f 5.0 0.01)   "Text5.0")))
                  	(entmod (subst (cons 8 lay) (assoc 8 on) on)
          (ssdel ob ss)
          )(princ)
usage:
command: Test3
HTH
Message 5 of 11
warrentdo
in reply to: phanaem
Hello Phanaem and thank you for your help.
Ive had a play and just changed             l (strcat "0-" (rtos (vla-get-height e) 2)"TEXT"))
Bow Ive forgot something. this would create a layer 0-3.5text and what I have to create is 0-35text.
All this becasue of a decimal point!! Client requirement.
I love the lisp though.
Cheers
Message 6 of 11
warrentdo
in reply to: pbejse
Thats the one.
(defun c:movetextfuzz (/ ss f on ob lay)
           (setq  f (cdr
                      (assoc 40
  (if (setq lay
            (cond
                   ((equal f 3.5 0.01)  "0-35TEXT")
                   ((equal f 5.0 0.01)   "0-50TEXT")))
                   ((equal f 7.0 0.01)   "0-70TEXT")))
          (ssdel ob ss)
          )(princ)
Cheers all.
Regards
Warren.
Message 7 of 11
Kent1Cooper
If such Text is put into the drawing by some kind of routine or menu item, or is in a Style that has a fixed height, I would think the fuzz factor would not be needed.  What's going to make a piece of Text come out with a height of 3.502?  It's not like checking the length of a Line or something.  If in fact the fuzz factor isn't needed, it can be quite simple:
(command
   "_.chprop" (ssget "X" '((0 . "TEXT") (40 . 3.5))) "" "_layer" "text3.5" ""
   "_.chprop" (ssget "X" '((0 . "TEXT") (40 . 5.0))) "" "_layer" "text5" ""
Kent Cooper, AIA
Message 8 of 11
robchapman82
Hi all,
I tried to butcher the lisps provided to suit my own requirements, but have failed miserably...
Rather than searching for a specfic height value, I tried to make the lisp ask me for a content variable.
I have a survey dwg with hundreds of spot levels. I'd like to put all text with content "123.84" onto a layer of the same name.
Although I could amend the lisp to search for all text of 123.96 through to 124.10, I was hoping to make it a useful tool for the future.
Either a lisp that put all text onto a corresponding layer (although this would mean that notes went into layers called "do not scale from this drawing" etc.)
...or a lisp that asked me for the content I'd like (123.84), selected all text with that content, and put it onto a layer of the same name.
Am I barking up the wrong tree, or could your previous lisp solutions be tweaked to serve my purpose?
Many thanks!
Rob
Tags (3)
Message 9 of 11
pbejse
in reply to: robchapman82
@robchapman82 wrote:
Hi all,
Many thanks!
Rob
a simple code could  be
(defun c:Tolayer ( / num ss i e l)
(while (not (progn
  		(setq num (getstring "\nEnter value to search: "))
  		(if (numberp (read num)) num
                    (and (princ "\n<Invalid number>") nil)))))
(if (setq ss (ssget "_X" (list '(0 . "TEXT")(cons 1 (strcat "*" num "*")))))
			(setq e (entget (ssname ss (setq i (1- i))))
                  	      l (assoc -1 e))
                  	 (entmod (list (cons 8 num) l)))
(princ "\nValue not found") )(princ) )
O would you rather have the routine select all  string with a valid numerical value  and use a range between x and x. now it would be fun to write a code to do just that
Message 10 of 11
robchapman82
in reply to: pbejse
Is that possible?!
I didn't even know I wanted that... but now it seems like a perfect idea...!
The routine provided worked perfectly. Thanks!
Message 11 of 11
pbejse
Is that possible?!
It is possible, [ i think....] , but it would require a set of condtions to follow. but i'm not saying i'm going to write it now though 😄 . If the need requries it, i'll probably do it just for fun.
You are welcome, Glad it works for you.
Cheers
”Boost
