Visual LISP, AutoLISP and General Customization
modify entity during an open dialoge box
6 REPLIES 6
158 Views, 6 Replies
I use this under a button to rotate a block during an open dialoge box.
(entmod (subst (cons 50 (+ (rng (cdr (assoc 50 (entget enm)))) tel))
(assoc 50 (entget enm)) (entget enm))) (entupd enm)
It works, but the rotation of the block, wil only get visible when I
reposition the dialogebox.
Can it be made to make the block rotate instantly?
Hope someone can help.
M
6 REPLIES 6
Tom Smith
AFAIK, no.
"discussion.autodesk.com" wrote in message news:5793630@discussion.autodesk.com...
M
You could simply hide the dialog box when you press the button to rotate the block and restore it afterwards.
It may happen so quickly that it is essentially invisible.
Mel
pciganek
Try this:
add (vl-load-com) at the start of your function and call
(vla-ZoomScaled
(vlax-get-acad-object)
1.0 acZoomScaledRelative
after each entmod - this "refreshes" the screen.
Peter
dgorsman
I do this sort of function differently - hide the dialog box and check for mouse input, right click rotates it one increment, left click returns to the dialog.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
I thought it would flip to much, but I can barely see it.
Thanx!
"MelFranks" schreef in bericht
news:5794037@discussion.autodesk.com...
M
Mel
Interesting. I´ll check it out. Thanx!
schreef in bericht news:5794101@discussion.autodesk.com...
Try this:
(vla-ZoomScaled
Peter
”Boost
