mm2 to m2 arealabel lisp
17 REPLIES 17
Message 1 of 18
lanieuwe
1971 Views, 17 Replies
I have a two questions about this lisp file AreaLabelV1-9.
First question is about conversion:
cf 1.0 ;; Area Conversion Factor (e.g. 1e-6 = mm2->m2)
I want m2 instead of mm2. What's the exact code for this?
Second question:
What if there is a "island" in the area. (A room in a room) . Now area (autocad) calculate the bigest room incl. the room inside. Is there a solution for this with lisp?
thank you.
gr. Laszlo
;;---------------------=={ Area Label }==---------------------;;
;;  Allows the user to label picked areas or objects and      ;;
;;  either display the area in an ACAD Table (if available),  ;;
;;  optionally using fields to link area numbers and objects; ;;
;;  or write it to file.                                      ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Version 1.9    -    29-10-2011                            ;;
(defun c:AT nil (AreaLabel   t))  ;; Areas to Table
(defun c:AF nil (AreaLabel nil))  ;; Areas to File
(defun AreaLabel ( flag / *error* _startundo _endundo _centroid _text _open _select _getobjectid _isannotative
                          acdoc acspc ap ar as cf cm el fd fl fo n of om p1 pf pt sf st t1 t2 tb th ts tx ucsxang ucszdir )
  ;;                         Adjustments                        ;;
  (setq h1 "Area Table"  ;; Heading
        t1 "Number"      ;; Number Title
        t2 "Area"        ;; Area Title
        pf ""            ;; Number Prefix (optional, "" if none)
        sf ""            ;; Number Suffix (optional, "" if none)
        ap ""            ;; Area Prefix (optional, "" if none)
        as ""            ;; Area Suffix (optional, "" if none)
        fd t             ;; Use fields to link numbers/objects to table (t=yes, nil=no)
        fo "%lu6%qf1"    ;; Area field formatting
  (defun *error* ( msg )
    (if cm (setvar 'CMDECHO cm))
    (if el (progn (entdel el) (setq el nil)))
    (if acdoc (_EndUndo acdoc))
    (if (and of (eq 'FILE (type of))) (close of))
    (if (and Shell (not (vlax-object-released-p Shell))) (vlax-release-object Shell))
    (if (null (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
        (princ (strcat "\n--> Error: " msg))
    (princ)
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)
  (defun _centroid ( space objs / reg cen )
    (setq reg (car (vlax-invoke space 'addregion objs))
          cen (vlax-get reg 'centroid)
    (vla-delete reg) (trans cen 1 0)
  (defun _text ( space point string height rotation / text )
    (setq text (vla-addtext space string (vlax-3D-point point) height))
    (vla-put-alignment text acalignmentmiddlecenter)
    (vla-put-textalignmentpoint text (vlax-3D-point point))
    (vla-put-rotation text rotation)
    text
  (defun _Open ( target / Shell result )
    (if (setq Shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
      (progn
        (setq result
          (and (or (eq 'INT (type target)) (setq target (findfile target)))
            (not
              (vl-catch-all-error-p
                (vl-catch-all-apply 'vlax-invoke (list Shell 'Open target))
    result
  (defun _Select ( msg pred func init / e ) (setq pred (eval pred))
    (while
      (progn (setvar 'ERRNO 0) (apply 'initget init) (setq e (func msg))
        (cond
          ( (= 7 (getvar 'ERRNO))
            (princ "\nMissed, try again.")
          ( (eq 'STR (type e))
            nil
          ( (vl-consp e)
            (if (and pred (not (pred (setq e (car e)))))
              (princ "\nInvalid Object Selected.")
    e
  (defun _GetObjectID ( doc obj )
    (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
      (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false)
      (itoa (vla-get-Objectid obj))
  (defun _isAnnotative ( style / object annotx )
    (and
      (setq object (tblobjname "STYLE" style))
      (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative")))))
      (= 1 (cdr (assoc 1070 (reverse annotx))))
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
        acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
        ucszdir (trans '(0. 0. 1.) 1 0 t)
        ucsxang (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 ucszdir))
  (_StartUndo acdoc)
  (setq cm (getvar 'CMDECHO))
  (setvar 'CMDECHO 0)
  (setq om (eq "1" (cond ((getenv "LMAC_AreaLabel")) ((setenv "LMAC_AreaLabel" "0")))))
  (setq ts
    (/ (getvar 'TEXTSIZE)
      (if (_isAnnotative (getvar 'TEXTSTYLE))
        (cond ( (getvar 'CANNOSCALEVALUE) ) ( 1.0 )) 1.0
  (cond
    ( (not (vlax-method-applicable-p acspc 'addtable))
      (princ "\n--> Table Objects not Available in this Version.")
    ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER))))))
      (princ "\n--> Current Layer Locked.")
    ( (not
        (setq *al:num
          (cond
              (getint
                (strcat "\nSpecify Starting Number <"
                  (itoa (setq *al:num (1+ (cond ( *al:num ) ( 0 ))))) ">: "
            ( *al:num )
    ( flag
      (setq th
        (* 2.
          (if
            (zerop
              (setq th
                (vla-gettextheight
                  (setq st
                    (vla-item
                      (vla-item
                        (vla-get-dictionaries acdoc) "ACAD_TABLESTYLE"
                      (getvar 'CTABLESTYLE)
                  acdatarow
            ts
            (/ th
              (if (_isAnnotative (vla-gettextstyle st acdatarow))
      (if
        (cond
            (progn (initget "Add")
              (vl-consp (setq pt (getpoint "\nPick Point for Table <Add to Existing>: ")))
            (setq tb
              (vla-addtable acspc
                (vlax-3D-point (trans pt 1 0)) 2 2 th (* 0.8 th (max (strlen t1) (strlen t2)))
            (vla-put-direction tb (vlax-3D-point (getvar 'UCSXDIR)))
            (vla-settext tb 0 0 h1)
            (vla-settext tb 1 0 t1)
            (vla-settext tb 1 1 t2)
            (while
              (progn
                (if om
                  (setq p1
                    (_Select (strcat "\nSelect Object [Pick] <Exit>: ")
                     '(lambda ( x )
                        (and
                          (vlax-property-available-p (vlax-ename->vla-object x) 'area)
                          (not (eq "HATCH" (cdr (assoc 0 (entget x)))))
                          (or (eq "REGION" (cdr (assoc 0 (entget x)))) (vlax-curve-isclosed x))
                      entsel '("Pick")
                  (progn (initget "Object") (setq p1 (getpoint "\nPick Area [Object] <Exit>: ")))
                (cond
                  ( (null p1)
                    (vla-delete tb)
                  ( (eq "Pick" p1)
                    (setq om nil) t
                  ( (eq "Object" p1)
                    (setq om t)
                  ( (eq 'ENAME (type p1))
                    (setq tx
                      (cons
                        (_text acspc
                          (_centroid acspc (list (setq p1 (vlax-ename->vla-object p1))))
                          (strcat pf (itoa *al:num) sf)
                          ts
                          ucsxang
                        tx
                    (vla-insertrows tb (setq n 2) th 1)
                    (vla-settext tb n 1
                      (if fd
                        (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                          (_GetObjectID acdoc p1) ">%).Area \\f \"" fo "\">%"
                        (strcat ap (rtos (* cf (vla-get-area p1)) 2) as)
                    (vla-settext tb n 0
                      (if fd
                          (_GetObjectID acdoc (car tx)) ">%).TextString>%"
                    nil
                  ( (vl-consp p1)
                    (setq el (entlast))
                    (vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_P" "" "_non" p1 "")
                    (if (not (equal el (setq el (entlast))))
                      (progn
                        (setq tx
                          (cons
                            (_text acspc
                              (_centroid acspc (list (vlax-ename->vla-object el)))
                              ts
                              ucsxang
                            tx
                        (vla-settext tb n 1 (strcat ap (rtos (* cf (vlax-curve-getarea el)) 2) as))
                        (vla-settext tb n 0
                          (if fd
                        (redraw el 3)
                        nil
                      (vla-delete tb)
            (not (vlax-erased-p tb))
            (and
              (setq tb
                (_Select "\nSelect Table to Add to: "
                 '(lambda ( x ) (eq "ACAD_TABLE" (cdr (assoc 0 (entget x))))) entsel nil
              (< 1 (vla-get-columns (setq tb (vlax-ename->vla-object tb))))
            (setq n (1- (vla-get-rows tb)) *al:num (1- *al:num))
        (progn
          (while
            (if om
              (setq p1
                (_Select (strcat "\nSelect Object [" (if tx "Undo/" "") "Pick] <Exit>: ")
                 '(lambda ( x )
                    (and
                  entsel (list (if tx "Undo Pick" "Pick"))
              (progn (initget (if tx "Undo Object" "Object"))
                (setq p1 (getpoint (strcat "\nPick Area [" (if tx "Undo/" "") "Object] <Exit>: ")))
            (cond
              ( (and tx (eq "Undo" p1))
                (vla-deleterows tb n 1)
                (vla-delete (car tx))
                (setq n (1- n) tx (cdr tx) *al:num (1- *al:num))
              ( (eq "Undo" p1)
                (princ "\n--> Nothing to Undo.")
              ( (eq "Object" p1)
                (setq om t)
              ( (eq "Pick" p1)
                (setq om nil)
              ( (and om (eq 'ENAME (type p1)))
                (setq tx
                  (cons
                    (_text acspc
                      (strcat pf (itoa (setq *al:num (1+ *al:num))) sf)
                      ts
                      ucsxang
                    tx
                (vla-insertrows tb (setq n (1+ n)) th 1)
                (vla-settext tb n 1
                  (if fd
                (vla-settext tb n 0
                  (if fd
              ( (vl-consp p1)
                (setq el (entlast))
                  (progn
                    (setq tx
                      (cons
                        (_text acspc
                          ts
                          ucsxang
                        tx
                    (vla-settext tb n 0
                      (if fd
                    (redraw el 3)
                  (princ "\n--> Error Retrieving Area.")
      (and
        (setq fl (getfiled "Create Output File" (cond ( *file* ) ( "" )) "txt;csv;xls" 1))
        (setq of (open fl "w"))
      (setq *file*  (vl-filename-directory fl)
            de      (cdr (assoc (strcase (vl-filename-extension fl) t) '((".txt" . "\t") (".csv" . ",") (".xls" . "\t"))))
      (write-line h1 of)
      (write-line (strcat t1 de t2) of)
      (while
        (if om
          (setq p1
             '(lambda ( x )
                (and
              entsel '("Pick")
          (progn (initget "Object") (setq p1 (getpoint (strcat "\nPick Area [Object] <Exit>: "))))
        (cond
          ( (eq "Object" p1)
            (setq om t)
          ( (eq "Pick" p1)
            (setq om nil)
            (_text acspc
              ts
              ucsxang
            (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vla-get-area p1)) 2) as) of)
          ( (vl-consp p1)
            (setq el (entlast))
              (progn
                (_text acspc
                  ts
                  ucsxang
                (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vlax-curve-getarea el)) 2) as) of)
                (redraw el 3)
      (setq of (close of))
      (_Open (findfile fl))
  (setenv "LMAC_AreaLabel" (if om "1" "0"))
  (_EndUndo acdoc)
  (princ)
(vl-load-com)
(princ)
(princ "\n:: AreaLabel.lsp | Version 1.9 | © Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Commands: \"AT\" for ACAD Table, \"AF\" for File ::")
(princ)
;;                         End of File                        ;;
Tags (1)
17 REPLIES 17
Message 2 of 18
braudpat
in reply to: lanieuwe
Hello
For your 2nd question, I think that only MPOLYGONs (created with MAP or CIVIL) can be a solution !?
I am not at all a Lisp/Vlisp programmer but you have the answer to your 1st question inside the code !
Change the line as according the comment :  cf  1e-6
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 18
lanieuwe
in reply to: braudpat
Thanks but...
No, I tried  that 1.0 or 1e-6. The result is the same a rectangle drawed in autocad @5000,5000 resuts in area 25000000.0000  not in 25.0000.
I want the result in m2 thus 25.0000.
I can't see what im doing wrong.
Message 4 of 18
hmsilva
Try the code using the 'Pick Area' option...
Henrique
Message 5 of 18
lanieuwe
in reply to: hmsilva
Yes i did.
Verzonden vanaf Samsung Mobile
Message 6 of 18
braudpat
Hello
The Lee-Mac Routine seems OK with the Pick option and NOT with the Object option !?
Patrice BRAUD
Message 7 of 18
lanieuwe
both options pick option and object select option the same results in mm2 instead m2.
Laszlo
Message 8 of 18
hmsilva
@lanieuwe wrote:
Yes i did.
On this side works OK with the 'Conversion Factor' using the 'Pick Area' option, and work as expected...
Using the 'Object' option Lee's code will link the selected object and the result with a 'Field' and onors the Object area without using the 'Conversion Factor'.
To use the CF with the object option, try to change
fo "%lu6%qf1"
to
fo (strcat "%lu6%qf1%ct8[" (rtos cf) "]")
And for the second question, if there is a "island" in the area, you'll need to create an region with the "island" in it and use the 'Select Object' option.
Henrique
Message 9 of 18
braudpat
Hello hmsilva
Thks, you are right for the Regions !
I am using a little bit too much MAP and the MPolygons ...
Patrice BRAUD
Message 10 of 18
hmsilva
@braudpat wrote:
Hello hmsilva
Hi Patrice,
I'm not a MAP guy, so I don't use MPolygons.
Henrique
Message 11 of 18
lanieuwe
Thank you hmsilva.
Unfortunately...
With the 'pick area' option it works great. For example the result is 25.00 m2
With the 'Object"option it isn't. For example (the same area) the result is 0.00 m2.
see code:
  ;;                         Adjustments                        ;;
        cf 1e-6	        ;; Area Conversion Factor (e.g. 1e-6 = mm2->m2)
        fo (strcat "%lu6%qf1%ct8[" (rtos cf) "]")    ;; Area field formatting
    (princ)
    text
      (progn
        (setq result
            (not
    result
    (while
        (cond
            nil
          ( (vl-consp e)
    e
    (and
  (_StartUndo acdoc)
  (setvar 'CMDECHO 0)
  (setq ts
  (cond
    ( (not
        (setq *al:num
          (cond
              (getint
            ( *al:num )
    ( flag
      (setq th
        (* 2.
          (if
            (zerop
              (setq th
                (vla-gettextheight
                  (setq st
                    (vla-item
                      (vla-item
                  acdatarow
            ts
            (/ th
      (if
        (cond
            (setq tb
              (vla-addtable acspc
            (while
              (progn
                (if om
                  (setq p1
                     '(lambda ( x )
                        (and
                      entsel '("Pick")
                (cond
                  ( (null p1)
                    (vla-delete tb)
                  ( (eq "Pick" p1)
                    (setq om nil) t
                  ( (eq "Object" p1)
                    (setq om t)
                    (setq tx
                      (cons
                        (_text acspc
                          ts
                          ucsxang
                        tx
                    (vla-settext tb n 1
                      (if fd
                    (vla-settext tb n 0
                      (if fd
                    nil
                  ( (vl-consp p1)
                    (setq el (entlast))
                      (progn
                        (setq tx
                          (cons
                            (_text acspc
                              ts
                              ucsxang
                            tx
                        (vla-settext tb n 0
                          (if fd
                        (redraw el 3)
                        nil
                      (vla-delete tb)
            (and
              (setq tb
        (progn
          (while
            (if om
              (setq p1
                 '(lambda ( x )
                    (and
            (cond
              ( (eq "Undo" p1)
              ( (eq "Object" p1)
                (setq om t)
              ( (eq "Pick" p1)
                (setq om nil)
                (setq tx
                  (cons
                    (_text acspc
                      ts
                      ucsxang
                    tx
                (vla-settext tb n 1
                  (if fd
                (vla-settext tb n 0
                  (if fd
              ( (vl-consp p1)
                (setq el (entlast))
                  (progn
                    (setq tx
                      (cons
                        (_text acspc
                          ts
                          ucsxang
                        tx
                    (vla-settext tb n 0
                      (if fd
                    (redraw el 3)
      (and
      (write-line h1 of)
      (while
        (if om
          (setq p1
             '(lambda ( x )
                (and
              entsel '("Pick")
        (cond
          ( (eq "Object" p1)
            (setq om t)
          ( (eq "Pick" p1)
            (setq om nil)
            (_text acspc
              ts
              ucsxang
          ( (vl-consp p1)
            (setq el (entlast))
              (progn
                (_text acspc
                  ts
                  ucsxang
                (redraw el 3)
  (_EndUndo acdoc)
  (princ)
(vl-load-com)
(princ)
(princ)
;;                         End of File                        ;;
 gr. Laszlo
Message 12 of 18
hmsilva
My bad...
(rtos cf 2 6)
Henrique
Message 13 of 18
lanieuwe
Thank you very much all!
gr. László
Message 14 of 18
braudpat
Hello
Please remind that hmsylva did all the job, so you can give him a Kudos (Compliment) !
Patrice BRAUD
Message 15 of 18
lanieuwe
Of course I did 😉
Message 16 of 18
hmsilva
@braudpat wrote:
Please remind that hmsylva did all the job...
Patrice,
thank you for your kind words, but who really did all the work was Lee Mac, I just made some adjustments to the OP.
Cheers
Henrique
Message 17 of 18
telmorosado
Hello to all,
someone can explain me how to put only 2 numbers after comma.
thanks
Message 18 of 18
hmsilva
in reply to: telmorosado
@telmorosado wrote:
Hello to all,
thanks
Hello Telmo and welcome to the Autodesk Community!
in ' Adjustments' in line
Lee has left the funtion 'rtos' without defining units and precision to honor dwg settings.
'to put only 2 numbers after comma' change (rtos cf) to (rtos cf 2 2)
Hope this helps,
Henrique
”Boost
