mleader
4 REPLIES 4
john-B
402 Views, 4 Replies
mleader
Hi all
I'm trying to write a lisp routine that, when I invoke the mleader command, osmode is set to "nearest" & orthomode is set off. I then would like the original settings to be returned.
attached is what I have written so far:-
Hoping for so help.
Regards
JohnB
4 REPLIES 4
devitg
in reply to: john-B
You need to add so many PAUSE , as need at (command "_mleader" pause pause ..... pause )
pbejse
in reply to: devitg
Use while
(command "_mleader")
(while (> (getvar "CMDACTIVE") 0)
(command pause))
john-B
in reply to: pbejse
Thank you both
pbejse
in reply to: john-B
@john-B wrote:
Thank you both
You are welcome, glad we could help 🙂
Cheers
”Boost
