Visual LISP, AutoLISP and General Customization
MLeader pickpoint and Z placement
9 REPLIES 9
Message 1 of 10
JCprog
436 Views, 9 Replies
Hello Everyone 🙂
I found this very useful code (below) at the swamp (credit to the guy who wrote it.....many thanks!). The routine will tag conduits by placing mleader which works perfect. The only problem is it always place the tag at 0 elevation. It would be nice if it sticks to the same elevation I picked. Please help. Thanks in advance 🙂
(defun c:cndtag ( / CNDEnt CNDObj PickPoint TagPoint CNDSize CNDSystem CNDTag)
(vl-load-com)
(setq 	CNDEnt (entsel "\nSelect the conduit to tag... ")
		CNDObj (vlax-ename->vla-object (car CNDEnt))
		PickPoint (cadr CNDEnt)
		TagPoint (getpoint PickPoint "\nPosition of conduit tag... ")
(setq	CNDSize (substr (vlax-get-property CNDObj "SizeName") 1 4))
(cond
	((= (substr CNDSize 2 3) ".00")(setq CNDSize (substr CNDSize 1 1)))
	((= (substr CNDSize 2 3) ".25")(setq CNDSize (strcat (substr CNDSize 1 1) " 1/4")))
	((= (substr CNDSize 2 3) ".50")(setq CNDSize (strcat (substr CNDSize 1 1) " 1/2")))
	((= (substr CNDSize 2 3) ".75")(setq CNDSize (strcat (substr CNDSize 1 1) " 3/4")))
(if	(= (substr CNDSize 1 2) "0 ")
	(setq CNDSize (vl-string-left-trim "0 " CNDSize))
(setq	CNDSystem (vlax-get-property CNDObj "Description")
		CNDTag (strcat CNDSize "\" C, " CNDSystem)
(command "_MLEADER" PickPoint TagPoint CNDTag)
9 REPLIES 9
Message 2 of 10
Shneuph
in reply to: JCprog
Is this possibly just a matter of setting "OSNAPZ" to 0?
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 3 of 10
JCprog
in reply to: Shneuph
Hello Shneuph, thanks for ur reply. my osnapz is turned off and shouldnt matter or I dont want the osnapz to take any part on this routine. Basically I just need it to act like the OTB tags.
Message 4 of 10
hmsilva
in reply to: JCprog
Hi JCprog,
the returned point from 'entsel' function, is the crosshair location when you select the object, not a point from the object...
To get the point on the object you'll need to test the object points, to find the closer to the returned point, or using 'osnsp'
(setq ZPoint (osnap PickPoint "End"))
or
(setq ZPoint (osnap PickPoint "nea"))
or the necessary osnap
HTH
Henrique
Message 5 of 10
JCprog
in reply to: hmsilva
Hello Henrique, I get this error somehow:
bad argument type: 2D/3D point: nil
I just need it to behave like a normal mleader.
Message 6 of 10
hmsilva
in reply to: JCprog
Maybe changing
to
(command "_MLEADER" ZPoint TagPoint CNDTag)
Henrique
Message 7 of 10
JCprog
I got this:
Command: CNDTAG
Position of conduit tag... Unknown command "1/2" C, ". Press F1 for help.
nil
Looks like it still looking for the "PickPoint"
Message 8 of 10
hmsilva
in reply to: JCprog
@JCprog wrote:
I got this:
Command: CNDTAG
nil
Try
(defun c:cndtag	(/ CNDEnt CNDObj PickPoint TagPoint CNDSize CNDSystem CNDTag)
  (vl-load-com)
  (if
    (and (setq CNDEnt (entsel "\nSelect the conduit to tag... "))
	 (setq CNDObj (vlax-ename->vla-object (car CNDEnt)))
	 (setq PickPoint (osnap (cadr CNDEnt) "nea"))
	 (setq TagPoint (getpoint PickPoint "\nPosition of conduit tag... "))
	 (vlax-property-available-p CNDObj "SizeName")
	 (vlax-property-available-p CNDObj "Description")
	 (setq CNDSystem (vlax-get-property CNDObj "Description"))
     (progn
       (cond
	 ((= (substr CNDSize 2 3) ".00") (setq CNDSize (substr CNDSize 1 1)))
       (setq CNDTag (strcat CNDSize "\" C, " CNDSystem))
  (princ)
Untested...
Henrique
Message 9 of 10
JCprog
WOW!!!!! That worked awesome!!!!!Smiley Very Happy
Thanks Henrique!
Message 10 of 10
hmsilva
in reply to: JCprog
You're welcome, JCprog
Glad I could help
Henrique
”Boost
