this is just a general post that i have made and saved... hope this helps..
it is wise if you were to create your own mnu file with your name. follow
these steps:
1) i would create your own folder in the "my documents" folder so you can
save your bmp files and a back up of your mns file.
2) copy all bmp from your acad2000i folder to this new folder. remember, you
will need them to use with your toolbars.
3) now i would locate and open (by clicking it) the acad.mns file. do a save
as and save it to your new folder and call it MyName.mnu
4) now in that file you will see this
***MENUGROUP=ACAD
rename that to
***MENUGROUP=MyName
now i would remove everything from this file with the exception of the
toolbar section... highlight all text before ***TOOLBARS hit backspace.
highlight all text after and including
// Begin AutoCAD Image Menus
hit backspace to erase all the text...
5) save it and copy it you your AutoCAD 2000i\support folder
in A2Ki you then will need to load this menufile using the menuload
command...
then i would close all the autocad toolbars and use all of yours. remember
that when you create a new toolbar to do it your menu not the autocad file..
this will then create (or update) the mns file.. this is the latest and
greatest version of the mnu file that you saved in the "my documents\my
folder"
if this does not make sense, ask me and i will try to explain better..
A2Ki, SurvCad CES, Win98 se
Remove NO SPAM from my email address to email
Jonathan J. Baker
R&R Engineers-Surveyors, Inc.
Denver, Colorado
_________________________
"Jason Piercey" wrote in message
news:BD59AA845FDD5F3120ED3AE3D8E688B5@in.WebX.maYIadrTaRb...
> Recently there has been many discussions on Base Menus and Partial Menus
and
> .mns vs. .mnu etc...... Search this group, I'm sure you will find enough
> information to answer your questions.
> -Jason
> "Matt Tyler" wrote in message
> news:290EB9D00429BB420EFD64CD3FCA249C@in.WebX.maYIadrTaRb...
> > Actually I used both, the final version that I ended up installing on
> > everybody's PCs was a .mnc, and I tried both on the one that didn't
work.
> > (copied in from a working machine) Does it matter, besides being easier
to
> > edit?
> > "John Scott" wrote in message
> > news:f08f0e8.0@WebX.maYIadrTaRb...
> > > Why didn't you use the MNS file rather than the MNC?
