I read Robert Bell's document “Migrating from MNU to the CUI” (Autodesk University 2007) with interest. I have been using 2005 up until now and I am finally forcing myself to get to grips with 2010. I know, it is ridiculous that I have waited this long.
Still using a tablet, still loving it. I managed to get it to work after much trial and error through the CUI transfer interface.
My customizing makes use of a lot of swapping pull-down menus, which swap in and out based on current later setting.
A typical command would be:
(MENUCMD "P15=RCASPOPS.mfireeqp") where RCASPOPS is my swapping menu loaded at POP15.
Then I would use (MENUCMD "P15=*") to force the “mfireeqp” area of the pull-down menu to display.
Trouble is, when I CUIload RCASPOPS, it does not seem to recognize the various areas of the menu.
Here is a part of that subsection of RCASPOPS:
***MFIREEQP
[FireProtEquipLayers]
[0]0;
[defpoints]defpoints;
[X-Refs]x----ref;
[Fire Prot. Total L&ayers - *]h-f*,*|h-f*;
[Fire Prot. Equip. L&ayers - *]h-fe*,*|h-fe*;
[->Fire Hose Ca&binet Group]
[&Fire Hose Cabinets - *]h-fe-cab*,*|h-fe-cab*;
[&STANDARD]h-fe-cab;
h-fe-cab-???,*|h-fe-cab-???,h-fe-cab,*|h-fe-cab;
[&EXIST]h-fe-cab-e;
h-fe-cab-???-e,*|h-fe-cab-???-e,h-fe-cab-e,*|h-fe-cab-e;
[&BASE]h-fe-cab-s;
h-fe-cab-???-s,*|h-fe-cab-???-s,h-fe-cab-s,*|h-fe-cab-s;
[&NEW]h-fe-cab-n;
h-fe-cab-???-n,*|h-fe-cab-???-n,h-fe-cab-n,*|h-fe-cab-n;
[&PLANNED]h-fe-cab-p;
h-fe-cab-???-p,*|h-fe-cab-???-p,h-fe-cab-p,*|h-fe-cab-p;
[&REMOVE]h-fe-cab-x;
[<-*]h-fe-cab-???-x,*|h-fe-cab-???-x,h-fe-cab-x,*|h-fe-cab-x;
Where am I going wrong?
Typically the whole of RCASPOPS is loaded but when I try to force it to display, the whole of it pops on the screen (well, the top of the file does anyway) and not just the subsection I want.
Is this a syntax issue with the newer AutoCad?
Also notice that I use the -> and <- for fly-out sections of the menu - is there a syntax issue with this?
I notice that the future support of drop down swapping menus is not guaranteed. What is the alternative?
I really would appreciate any hints, thanks in advance.
Oh, and happy new year!
