Toggle the menu echo?
RS_DelTxt [$(if,$(getenv,rs_deltxt),"!.")Delete text]^P(if (= (getenv
"rs_deltxt") "1") (setenv "rs_deltxt" "0") (setenv "rs_deltxt" "1"));^P
R. Robert Bell, MCSE
http://www.acadx.com
"Frédéric Chartier" wrote in message
news:2E55E96E14EE4482BD0306D43A635F0E@in.WebX.maYIadrTaRb...
| Hi again,
| I try to set a menu with a marking label, but i have a problem, i would
like
| that when it is set i hav an env value to T else nil ... not so easy to
| explain, so for now i've made this :
| RS_DelTxt [$(if,$(getenv,rs_deltxt),"!.")Delete text](if (= (getenv
| I know i have "0" or "1" to rs_deltxt but no pb for this.
| When i select the item in my menu, it prompt the command ... grrr ... so
| does someone have a solution to hide the command or to do it to a better
way
| (this one suck i guess !!)
