Mend Lines function - Needs Tweaking
3 REPLIES 3
m_johnson
208 Views, 3 Replies
Can anyone help with this one....We have a function called 'Mend' which basically reconnects to broken lines into a single object. When you run the function, it asks you to select the first line, then the second line, and turns them into a single line again, then the function ends. However, I would like the function to stay active so i can select further lines, until I press escape or cancel.
I am not very knowledgable with Lisp, therefore if anyone wants to have a look and tweak the function for me, I have attached the file. Even better, would be a function that allows me to select multiple lines rather than single objects.
Thanks in advance for any response.
Regards
Marc Johnson
3 REPLIES 3
in reply to: m_johnson
Just add this line into the end of your lisp file
(just before the last ")" )
(c:mend)
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
Can
objects.
Regards
Marc Johnson
Hi Marc
If you are using A2k+, you can try the attached program.
Cheers
Juerg Menzi
MENZI ENGINEERING GmbH, Switzerland
http://www.menziengineering.ch
try the AutoCAD command MULTIPLE
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Can
objects.
Regards
Marc Johnson
”Boost
