Visual LISP, AutoLISP and General Customization
Measure in millimeters but display values in meters...
18 REPLIES 18
Message 1 of 19
sean.keohane
1969 Views, 18 Replies
The attached lsp puts tick marks at equal distances along a line/polyline and tags them with the distanace value from the start point. I draw using millimeter units but things like chainage should be displayed in meter units. Using this routine displays the values in millimeter units which I then 'find and replace' to edit their values to meters.
Can someone take a look at the lisp to see if it can be altered to input the mm value at the start but output the meter value to the text values?
Attached jpg graphically shows my request.
Regards
Sean
18 REPLIES 18
Message 2 of 19
stevor
in reply to: sean.keohane
For you TEXT creation, line:
    (list (cons 1 (rtos chainage 2 3)))
could be changed;
to something like;
    (list (cons 1 (strcat  (rtos (/ chainage  1000.0) 2 3 ) "m " )  ) )
S
Message 3 of 19
Kent1Cooper
@sean.keohane wrote:
.... I draw using millimeter units but things like chainage should be displayed in meter units. Using this routine displays the values in millimeter units which I then 'find and replace' to edit their values to meters.
You should be able to do it by changing this line:
to something like this:
(list (cons 1 (strcat (rtos (/ chainage 1000) 2 1) "m")))
Kent Cooper, AIA
Message 4 of 19
sean.keohane
Thanks very much to both of you, that worked perfectly.
I appreciate your help,
Sean
Message 5 of 19
I have used the lisp discussed above but unfortunately the label (0+050.00, 0+100.00, etc) doesn't show, only the tick.
Also, I have seen drawings that has a tick interval of 50m but the label is placed only every 100m. The tick length on the place where there is label is longer that the one without label. Can you please reconfigure the above lisp so it would fit in my description?
Thank you in advance.
Message 6 of 19
pbejse
Text Style issues, you  can use a existing textstyle name
(list (cons 50 (+ bearing PI))) (list (cons 7 "YourTextStyle" )) '((41 . 1.0) (51 . 0.0) (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0) )
or remove it altogether . which will use the current TEXTSTYLE
HTH
EDIT: Almost forgot, for your format
(list (cons 1 (strcat "0+" (rtos chainage 2 2))))
Message 7 of 19
in reply to: pbejse
Thank you very much for the swift reply.
I have used your latest suggestion but it didn't work out as I expected.
I wanted to remove the "m" on the suffix of each label. The label on the starting point (0+000.00) doesn't show.
Labels should look like this:
0+000.00
0+050.00
0+100.00
0+150.00
etc.
Also, the increment that I have entered is 50m. Why is it that the label doesn't have a 50m interval?
Please have a look on the attached jpeg file in order to have a clear idea on what I wanted.
Thanks again.
Message 8 of 19
pbejse
0+000.00
0+050.00
0+100.00
0+150.00
etc.
Thanks again.
works fine here in 2009
(defun c:Chainage (/)
(vl-load-com)
(defun _Line (p b o)
       (entmake
	 (append
	   '((0 . "line")
	     (100 . "AcDbEntity")
	     (67 . 0)
	     (410 . "Model")
	     (8 . "C_Chainage")
	     (100 . "AcDbLine")
	   (list (cons 10 (polar p b o)))
	   (list (cons 11 (polar p (+ b PI) o)))
	   '((210 0.0 0.0 1.0))
(defun _text (p b o h c)
       (entmake
	 (append
	   '((0 . "TEXT")
	     (67 . 0)
	     (410 . "Model")
	     (8 . "C_Chainage")
	     (100 . "AcDbText")
	   (list (cons 10 (polar p (+ b PI) (* o 2.0)))
	   (list (cons 40 h))
				 (if (setq ld (nth (strlen (rtos  c 2 0)) '(x  "00" "0")))
				   	ld "")
				 (rtos c 2 2))))
	   (list (cons 50 (+ b PI)))
	   '((41 . 1.0)
	     (51 . 0.0)
	     (71 . 0)
	     (72 . 0)
	     (11 0.0 0.0 0.0)
	     (210 0.0 0.0 1.0)
	     (100 . "AcDbText")
	     (73 . 0)
(defun _ang (p1 p2)(+ (angle p1 p2) (/ PI 2.0)))
(setq dist (getdist "Type in chainage increment: "))
  (setq offset (getdist "Type in tick size: "))
  (setq height (getdist "Type in iso text height: "))
  (setq	ss (ssget)
	count 0
	dist dist
	offset offset
	height height
  (repeat (sslength ss)
    (setq ent	   (ssname ss count)
	  obj	   (vlax-ename->vla-object ent)
	  chainage dist
    (_line (setq p (vlax-curve-getstartpoint obj))
	   (setq bearing (_ang p (vlax-curve-getPointAtDist obj (+ chainage 0.001))))
		   offset)
    (_text p bearing offset height 0.0)
    (while
      (and
	(setq point1 (vlax-curve-getPointAtDist obj chainage))
	(setq point2 (vlax-curve-getPointAtDist obj (+ chainage 0.001)))
       (setq bearing (+ (angle point1 point2) (/ PI 2.0)))
       (_line point1 bearing offset)
       (_text point1 bearing offset height chainage)
       (setq chainage (+ chainage dist))
    (setq count (1+ count))
 HTH
BTW: what of the last point?
Message 9 of 19
in reply to: pbejse
Great! Works perfectly now.
This would be of great help and I will be forever grateful to you.
Thanks a lot and God bless!
Message 10 of 19
pbejse
You are welcome. even though this thread is a year ang change old the credit still goes to the original author @sean.keohane
Cheers
Message 11 of 19
in reply to: pbejse
I'm sorry but there seem to be a small glitch. I have tried it in polyline that is more than 1000m and it didn't work.
You see, when the chainage reaches 1,000m the label should be 1+000.00, 1+050.00, 1+100.00, etc (if the increment entered is 50m). "1+" stands for 1 kilometer. 2+000.00 means 2 km + 000.00 m and so on.
Again, thanks in advance.
Message 12 of 19
pbejse
Before i go any further. can you tell me what would be the longest possible length you have on your chainage?
Message 13 of 19
in reply to: pbejse
I am working with water network in Qatar and 1 line of pipe can go sometimes as far as 10 or even 20km.
Message 14 of 19
Alfred.NESWADBA
And what product do you use? If you have Civil3D you don't need any LISP, you can assign labeling with exactly that type of distance you describe.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 15 of 19
in reply to: Alfred.NESWADBA
I am sorry but I haven't used civil 3d up to now. ? I am using Autocad 2010 and I have not time yet studying civil 3d as the work at hand needs to be submitted in a day or two. ? Thanks a lot to those that could help me on this.
Message 16 of 19
pbejse
Okay
I include a quick fix
(defun _pad ().....
see attached file
Message 17 of 19
in reply to: pbejse
Works perfectly. I even tried up to more than 100km.
Thanks a lot pbejse!
God bless!
Message 18 of 19
marlance
in reply to: pbejse
Hi
How can I change the justification of the text to middle left?
I also want to replace the text to mtext so that it could have the option to have a background mask.
Thank you
Message 19 of 19
marlance
in reply to: marlance
Hi all
How can I replace the chainage increment value into elevation value of the polyline?
”Boost
