Regardless, the command should continue afte the b1 or b2 variable is entered even with no "" or points. It would just prompt for user input. The problem is that the entity name is no good for some reason...
Command: (tblnext "block" t)
((0 . "BLOCK") (2 . "44") (70 . 0) (10 0.0 0.0 0.0) (-2 . Entity name:
7efa51d8))
Command: (setq b1 (tblobjname "block" "44"))
Entity name: 7efa5200
Command: (command "move" b1 "" (list 0.0 0.0 0.0) (list 1.0 0.0 0.0))
Bad Entity name: 7EFA5200
nil
Command: (setq b2 (cdr (car (entget (tblobjname "block" "44")))))
Command: (command "move" b2 "" (list 0.0 0.0 0.0) (list 1.0 0.0 0.0))
nil
gt lt symbols omitted because they would make some text not show in the post.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
