i d like to understand how to manage VLX file
when i drag and drop one in acad , then type the command it works fine
but then
- creating a pgp alias : doesnt work , uinknown command
- load vlx and launch command from a lisp : does nothing
am i missing something ? are there other options ?
thanks
The VLX routine must be 'loaded' before using the alias.
Drag and drop is one way to load, but there are others.
Search for load, appload, vl-unload-vlx, Acaddoc, etal,
to see the various ways, with their limits and requirements.
To have a tool bar button load your lisp,
^C^C(if (not c:YourCommand)(load "C:/YourFile/Path/Lisps_and_VLX files/YourVLXFile.vlx"));YourCommand;
Or you can add the vlx file to your Contents start up suite in the APPLOAD manager.
