Visual LISP, AutoLISP and General Customization
Manage files using Lips-routines
4 REPLIES 4
gbra
342 Views, 4 Replies
Are there any Lisp functions to copy, rename and/or delete external files (not esp. drawings, could also be e.g. text files)?
4 REPLIES 4
jggerth1
in reply to: gbra
take a look at the doslib library functions from McNeel.com
in reply to: gbra
(vl-file-delete filename)
Arguments
filename
A string containing the name of the file to be deleted. If you do not
specify a full path name, vl-file-delete searches the AutoCAD default
drawing directory.
Return Values
T if successful; nil if delete failed.
Examples
Delete newauto.bat:
_$ (vl-file-delete "newauto.bat")
nil
Nothing was deleted because there is no newauto.bat file in the AutoCAD
default drawing directory.
Delete the newauto.bat file in the c:\ directory:
_$ (vl-file-delete "c:/newauto.bat")
T
The delete was successful because the full path name identified an existing
file.
in reply to: gbra
(vl-file-rename old-filename new-filename)
Arguments
old-filename
A string containing the name of the file you want to rename. If you do not
specify a full path name, vl-file-rename looks in the AutoCAD default
drawing directory.
new-filename
A string containing the new name to be assigned to the file.
NoteIf you do not specify a path name, vl-file-rename writes the renamed
file to the AutoCAD default drawing directory.
Return Values
T, if renaming completed successfully; nil if renaming failed.
Examples
_$ (vl-file-rename "c:/newauto.bat"
"c:/myauto.bat")
T
NoteIf the target file already exists, this function fails.
gbra
in reply to: gbra
Thanks!
”Boost
