Visual LISP, AutoLISP and General Customization
Making my lisp (fas) version dependant...
7 REPLIES 7
Message 1 of 8
The_Caddie
457 Views, 7 Replies
I would like to know how I can compare the value of a variable to a set string of text if the two prove to be equal perform task A if the two prove different perform task B?
7 REPLIES 7
Message 2 of 8
_Tharwat
in reply to: The_Caddie
Hi ,
Can you give an example of your variables and text's values ?
Maybe the function member is the one you looking for .
Message 3 of 8
The_Caddie
Well I want to compare the ACADVER variable with the text “18.2s (LMS Tech)” . then using the IF ELS method compare the tow values if the same go to IF, if different go to ELS. That’s the basic now I just want to know how / if at all its possible to compare and process the two values?
Message 4 of 8
_Tharwat
One way ....
(if (eq (getvar 'acadver) "18.2s (LMS Tech)")
  (princ "\n that's correct ")
  (princ "\n That's wrong ")
 Another ....
(if (wcmatch (getvar 'acadver) "18.2s (LMS Tech)")
Message 5 of 8
The_Caddie
in reply to: _Tharwat
Whats the diffrence between the two methods?
Message 6 of 8
_Tharwat
Actualy nothing , but with function wcmatch you can check the string if it has a specific string within e.g.
(wcmatch  (getvar 'acadver) "18.*")
but with eq function , the strings must be equal ( the same )
Message 7 of 8
Kent1Cooper
@_Tharwat wrote:
One way ....
(if (eq (getvar 'acadver) "18.2s (LMS Tech)")....
You can also use the (=) function for that [it will compare either text strings or numerical values]:
(if (= (getvar 'acadver) "18.2s (LMS Tech)")....
Kent Cooper, AIA
Message 8 of 8
_Tharwat
in reply to: Kent1Cooper
@Kent1Cooper wrote:
@_Tharwat wrote:
One way ....
That's right ,
and you can also use member function for the same result . e,g .
(member (getvar 'acadver) '("18.2s (LMS Tech)")
Tharwat
”Boost
