Visual LISP, AutoLISP and General Customization
make xref name as xref file name
5 REPLIES 5
788 Views, 5 Replies
I have some drawing's with huge amount of xref's but many of them have not same names as external xref file name. Example: internal xref name "arch-290612" connected to external file name "arh-231213" and so on..
How can I make xref name equal to external file name "all an once" per one lisp session (need lisp programm for it)?
5 REPLIES 5
hmsilva
As a 'demo'
(vl-load-com)
(defun c:demo (/ name) (vlax-For blk (vla-Get-Blocks (vla-Get-ActiveDocument (vlax-Get-Acad-Object)) ) (if (and (= (vla-Get-IsXref blk) :vlax-True) (not (wcmatch (vla-get-Name blk) (setq name (vl-filename-base (setq path (vla-get-path blk))) ) ) ) ) (if (not (vl-catch-all-error-p (vl-catch-all-apply '(lambda () (vla-put-Name blk name))) ) ) (vla-reload blk) ) ) ) (princ) )
Hope that helps
Henrique
in reply to: hmsilva
Henrique You are real Master. Works Perfect!
hmsilva
Glad it worked for you.
Henrique
darrell.l.gregg
just what I was looking for!
hmsilva
in reply to: darrell.l.gregg
Hi Darrel,
I'm glad it's useful for you!
Henrique
”Boost
