Dear Brothers,
I have to Qestions i have attach CAD for that two qestions
I want a lisp file to create Assoiciated region using separete poly line and separate hatch.i can do it command of create region and union command but if i do so its take some time i want to do it quickly using lisp file.please help me someone to do this
thanks
gamage
Solved by dicra. Go to Solution.
Hi ctpgamage,
Here is one quick code, minimum testing:
(defun c:ssunion (/ ss ssunion ename) (setq ss (ssget '((-4 . "<OR") (0 . "LWPOLYLINE") (0 . "HATCH") (-4 . "OR>"))) ) (setq ssunion (ssadd)) (while (setq ename (ssname ss 0)) (cond ((= "HATCH" (cdr (assoc 0 (entget ename)))) (command "-hatchedit" ename "b" "r" "n") ) ((= "LWPOLYLINE" (cdr (assoc 0 (entget ename)))) (command "region" ename "") ) );end cond (ssdel ename ss) (ssadd (entlast) ssunion ) ) (command "union" ssunion "") )
Hope that this is going to help you.
dicra
gamage,
You're welcome, glad I could help.
Here is one quick remark, I just added Lee Macs undo commands.
Whit these commands, if You need to use undo, it is not going to go step by step trough lisp.
(defun c:ssunion (/ ss ssunion ename) (defun *error* ( msg ) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (LM:startundo (LM:acdoc)) (setq ss (ssget '((-4 . "<OR") (0 . "LWPOLYLINE") (0 . "HATCH") (-4 . "OR>"))) ) (setq ssunion (ssadd)) (while (setq ename (ssname ss 0)) (cond ((= "HATCH" (cdr (assoc 0 (entget ename)))) (command "-hatchedit" ename "b" "r" "n") ) ((= "LWPOLYLINE" (cdr (assoc 0 (entget ename)))) (command "region" ename "") ) );end cond (ssdel ename ss) (ssadd (entlast) ssunion ) ) (command "union" ssunion "") (LM:endundo (LM:acdoc)) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) )
dicra
