Visual LISP, AutoLISP and General Customization
Maintain space between line and text
9 REPLIES 9
Message 1 of 10
377-83869076
628 Views, 9 Replies
Hi guys am new to this site
I need to know how to set gap between line and text by lisp and also i attached reference file plz give ur idea to do that........Thank Youdsd.png
text size 2.72
need gap 1.38
9 REPLIES 9
Message 2 of 10
Kent1Cooper
in reply to: 377-83869076
TEXTMASK has an Offset option, in which you can specify that distance as a proportion of the Text height.
Kent Cooper, AIA
Message 3 of 10
Kent1Cooper
Welcome to the Forums, by the way!  The code below, as a bare-bones starting point, seems to work in limited testing for orthogonally-oriented Text [with rotation angles of 0 or multiples of 90 degrees] such as your example, with selection of the Line [or other Trimmable object] inside the extent of the Text.
If it does what you want, as far as it goes, it can be enhanced/expanded to do any of these things that you might want:
Restrict object selection to an actual Text object and something Trimmable;
Proceed only if appropriate things are selected for both;
Work as expected with non-orthogonal Text;
Work with Mtext and/or Attribute definitions as well as plain Text;
Offer the option to specify the gap as a proportion of the Text height, rather than an absolute value;
Suppress command echoing so you don't "see" the Rectangle and Trim and Erase commands going by on the Command: prompt line;
Remember your gap value and offer it as a default on subsequent use;
Allow Trimming of more than one object "behind" the same Text object;
Allow selection of the object(s) to be trimmed at location(s) outside the Text;
Put it all in an overall Undo begin/end wrapper, so that U afterwards will back up through all of it at once, instead of in several steps;
Probably a few other little things.
(defun C:TEXTGAP (/ txt lin gap minpt maxpt box cut)
  (setq
    txt (car (entsel "\nSelect Text object: "))
    lin (entsel "\nSelect Line or other object to Trim, within extent of Text: ")
    gap (getdist "\nGap distance between Text and end of trimmed object: ")
  ); setq
  (vla-getboundingbox (vlax-ename->vla-object txt) 'minpt 'maxpt)
  (command "_.rectang" "_none" (vlax-safearray->list minpt) "_none" (vlax-safearray->list maxpt))
  (setq box (entlast))
  (vla-offset (vlax-ename->vla-object box) gap)
  (setq cut (entlast))
  (command "_.trim" cut "" (cadr lin) "" "_.erase" box cut "")
); defun
Kent Cooper, AIA
Message 4 of 10
377-83869076
in reply to: Kent1Cooper
Its ll really going to increase my workflow and very happy to say thank u so much for ur help..........Smiley Happy
Alwys keep in touch thank u once again bro...!!Smiley Very Happy
Message 5 of 10
377-83869076
hi kent i hav problem on abv given code was work perfectly in 2008 but in 2011 autocad said
Gap distance between Text and end of trimmed object: 1.38
; error: no function definition: VLAX-ENAME->VLA-OBJECT
so please find solution for what happened here...
Thank U
Message 6 of 10
Kent1Cooper
Thank U
Try doing
(vl-load-com)
first.  Maybe there was something in your 2008 setup that did that for you, and not in your 2011 setup.
Kent Cooper, AIA
Message 7 of 10
pbejse
Thank U
Please add (vl-load-com) as the last line of the code
 ..... (command "_.trim" cut "" (cadr lin) "" "_.erase" box cut "")
); defun
(vl-load-com);<----right there
 EDIT: oops, did not see Kents' post there.... Smiley Happy
Message 8 of 10
377-83869076
It's work thx kent
Message 9 of 10
Kent1Cooper
It's work thx kent
You're welcome.  Something in the setup here runs that for me automatically, so I never need to include it in code when I test things, and I often forget that many people need to have that added.  The more reminders I get, the more likely it is that I'll remember the next time....
Kent Cooper, AIA
Message 10 of 10
pbejse
Regarding "Mark as solution", back at you Kent Smiley Happy
@Kent1Cooper wrote:
You're welcome, but I couldn't take all the Accept-As-Solution credit for it, since I just tweaked Kents code <added one line really>.  So I have marked the original routine message also as [at least a part of] the Solution [we Expert Elites wield the awesome power to do that, even in threads we didn't initiate].
”Boost
