Visual LISP, AutoLISP and General Customization
Macro to Convert Lines to Polylines
10 REPLIES 10
Message 1 of 11
terrametrix
1618 Views, 10 Replies
I'm having difficulty with a creating a macro for a command to convert lines to polylines using the PEDIT command.
So far I'm trying to use ^C^C_PEDIT;M;\;; but I can't get it to close the PEDIT command. It just stops at the list of edits. I've tried to use a ^C at the end to close the command but to no avail.
Using AutoCAD 2013.
Any help will be greatly appreciated!
Thank you,
Tim
10 REPLIES 10
Message 2 of 11
FSJ_Mo
in reply to: terrametrix
I think you just need to add one more semi-colon at the end of your macro.
Message 3 of 11
terrametrix
Just tried adding the third semicolon and it still won't close the command. I keep getting stuck at the "Enter an option" portion of the command.
Thanks for the reply though.
Message 4 of 11
FSJ_Mo
Try changing the peditaccept variable to one first (and then you should only need the two semi-colons)
Message 5 of 11
terrametrix
Yep, setting PEDITACCEPT to "1" was one of the first things I did yesterday when I was having trouble. Still stuck at the "Enter an option" portion of the command.
Thanks again for the reply.
Message 6 of 11
FSJ_Mo
It works here on C3D 2012. sorry I couldn't be more help
Message 7 of 11
hmsilva
Something like this perhaps.
^C^C_peditaccept;1;_select;_auto;\_Pedit;_m;_p;;;
HTH
Henrique
Message 8 of 11
terrametrix
That did it!!! Many thanks to everyone that replied. I'm still confused as to why my original macro syntax didn't work but at least I have a working command.
Thanks again,
Tim
Message 9 of 11
hmsilva
You're welcome, Tim
Glad I could help
Henrique
Message 10 of 11
Lee_Mac
Using AutoCAD 2013.
Since you are using a full version of CAD, you could also use LISP, e.g.:
(defun c:pj ( / c p s )
    (if (setq s (ssget "_:L" '((0 . "LINE,ARC,LWPOLYLINE"))))
        (progn
            (setq p (getvar 'peditaccept)
                  c (getvar 'cmdecho)
            (setvar 'peditaccept 1)
            (setvar 'cmdecho 0)
            (command "_.pedit" "_M" s "" "_J" "" "")
            (setvar 'cmdecho c)
            (setvar 'peditaccept p)
    (princ)
LISP allows for more error trapping, and also defines a command which may be repeated rather than clicking a button for every use.
Message 11 of 11
Kent1Cooper
in reply to: Lee_Mac
(command "_.pedit" "_M" s "" "_J" "" "") ...
Without [conforming to the OP's original macro that only converts Lines separately] the Join option:
            (command "_.pedit" "_M" s "" "")
in which case there's no need to include Polylines in the selection set filter [they don't need conversion], and they should also consider whether or not they want Arcs.
Kent Cooper, AIA
”Boost
